eighteesix
bear with me: i just built a new system (specs below) and its been running great. ive decided to overclock and install an H60, but wanted to check temp under stress load first. the result shocked me. i was reading 30-40C idle, 92-98C under load. my intel HSF wasnt seated properly even though all the pins were secure, so i reseated it, which brought it down to around 80 under load.
today i switched to the corsair H60 (w/ pre-applied thermal paste) still at stock i7 2600K speed, and under stress load, i turned my fan control up, ran prime95, and im reading 57-63C (max). i feel like for stock settings thats still hot. is that true? is this running hot? any help/suggestions appreciated.
note:the h60 box has a chart that shows this: the H60 will keep the i7 920 @ 3.8Ghz at 100% load cooled to 78.9 C. so im assuming my numbers are probably fairly average. i dont know how the 2600k and 920 compare in heat, but its a gauge of sorts i suppose.
using prime95/realtemp/cpu-z/optimal BIOS defaults
GIGABYTE GA-Z68XP-UD3P
i7-2600K 3.4GHz
CORSAIR Vengeance 16GB DDR3
GIGABYTE Radeon HD 6870 1GB ]
CORSAIR TX750M
CORSAIR H60 Cooler
Corsair 600T Case
i7-2600K 3.4GHz
CORSAIR TX750M
CORSAIR H60 Cooler
Corsair 600T Case
