Denithor
- Apr 11, 2004
- 6,298
- 23
- 81
Not sure where atl got his numbers but they actually look pretty reasonable, in line with what I'd expect from those setups. Assuming of course that the encoding software takes full advantage of all 12 Opteron cores...
To the second portion, most editing software is single threaded so you're only going to be using one core while doing that portion of the work. And since 1 2600k core is about 2x the performance of 1 Opty core @ 2.6GHz the editing will be sluggish and take twice as long if you opt for the Opty.
So you need to look at what amount of time is used for various tasks (editing versus encoding) to see which will actually be better.
One final factor to consider: even if the initial cost is equal up front, the dual Opteron system is going to cost far more long term due to much higher energy consumption.
