The temp jumping from 26C to 40C during idle can be explained by the intel speedstep option. Your clock and vcore will increase as you use your pc. With my 2500K it sits at around 28C when im doing absolutely nothing. When Im listening to music or on the internet the temp will go up a little depending on what I'm doing since the CPU isn't sitting at idle anymore, it's clock and vcore fluctuate depending on the load that is put on the chip. If you want to heat the chip up a little more, Intel Burn Test or LinX will stress the chip a bit more. Again, idle temps shouldn't be anything to be concerned about though. The load temps is what you want to look at and keep under control.
