i5 3230M (2.60GHz) vs i7 3630QM (2.40GHz) for gaming
Discussion in 'CPUs and Overclocking' started by antobag, Feb 26, 2013.
  1. antobag
    antobag Junior Member
    Feb 26, 2013
    24
    Okay, thanks to everyone! I'm going to keep looking around and see what's best for me, but your help has been extremely useful.
  2. LanceAvion
    LanceAvion Junior Member
    Feb 26, 2013
    7
    I/m not sure what your price range is but have you considered the Lenovo Ideapad y400/y500 models?
    y400: http://shop.lenovo.com/SEUILibrary/c...3B&action=init
    y500: http://shop.lenovo.com/SEUILibrary/c...FB&action=init
    Basically they are 14" and 15" models of the same computer, which the max resolution of the y400 at 1366x768 and the y500 at 1080p. They come equipped with a powerful i7 3630QM CPU and a 650M GPU. However this particular model also has a capacity to swap out the optical bay (DVD drive) for another 650M which can run in SLI with the first. This boosts the graphical performance to the level of the 670M in supported games. Take a look at these benchmarks.
    Single 650M: http://www.notebookcheck.net/NVIDIA-GeForce-GT-650M.71887.0.html
    Dual 650Ms: http://www.notebookcheck.net/NVIDIA-GeForce-GT-650M-SLI.84953.0.html
    These laptops are really the best bang for your buck if you have a budget. If you can spend more look into Sager and MSI.
  3. Enigmoid
    Enigmoid Platinum Member
    Sep 27, 2012
    2,908
    23
    Go with the i7. Battery life difference will be marginal (maybe 10%) under light load (and im asuming that whenever you will be using the battery you will be using the computer lightly--no gaming, etc because few people game on battery). i7 mobile idles at around 3-4 watts. Cutting it down to an i5 much change that to 2-3 watts. There will be a bigger difference if you up the brightness on the laptop, or use a 1080p screen instead of a 768p one. Anandtech did a review on an acer laptop with a ULV i5 and a 640m and they were cpu bottlenecked a few times. Note that a ULV i5 is only 10-20% slower than a i5 standard voltage and the 650m is about 10-30% faster than the 640m
  4. antobag
    Feb 26, 2013
    24
    Thanks for the heads up about these laptops! If I swapped out the optical bay, would this mean I would need to purchase an external DVD drive to use CDs etc?
    This is interesting. I was under the impression that it was the other way around (ie. the CPU being bottlenecked by the 650m GPU). I do want to use a 1080p screen but I'll have the laptop plugged in most of the time anyway (I'm currently using an old Dell XPS M1530 on which the battery dies out after 5 minutes of normal use, so I'm used to using the cable!) I'm definitely tempted now to splash out on the i7.
  5. antobag
    Feb 26, 2013
    24
    Apologies for the double post. I don't seem to have the option of deleting it so I've just replaced it with this one.
    #30 antobag, Feb 27, 2013
  6. NTMBK
    NTMBK Diamond Member
    Nov 14, 2011
    7,548
    398
    Yeah, you'd need to get a USB DVD drive. These are fairly cheap though, and given how frequently laptop DVD drives malfunction it's not a bad idea anyway. (Me and almost all my friends have had their laptop optical drives fail or become unreliable before the rest of the machine.)
  7. antobag
    Feb 26, 2013
    24
    Thanks for the reply. Running in SLI would definitely solve my GPU problems.
  8. LanceAvion
    Feb 26, 2013
    7
    Yep just as NTMBK said you'll need a USB DVD drive while the second 650M is in the optical bay. However if you don't need the second 650M for a certain task, such as watching a movie, but you would like the DVD drive just put it back in. That is the beauty of swappable components.
  9. antobag
    Feb 26, 2013
    24
    Is there a way of finding out whether a laptop can swap out its optical drive for a GPU? The laptop I'm looking at is the 15.6" Enigma IV on PC Specialist, which is based on a Clevo/Sager chassis (although I'm not sure which one). Does anyone know if these laptops have the same swap-out feature? I'm guessing it's quite rare?
    EDIT: Actually, I think the Enigma is based on a Compal QAL51.
    #34 antobag, Feb 28, 2013
