Charlie98
Interesting. I really do think it is a VCore issue. ANd if you're havingt he heat problem on that HSF, then it is not the culprit.
I went in and reset everything to stock and worked my way back up to 4.2GHz, then I started reducing vCore... just dropping the voltage dropped the temps 10C. I reduced it all the way down .10v where it finally crashed, so I bumped the voltage back up to -.08 and dropped the clock to 4.1GHz where I am now. Under full memory load on LinX I get a top temp of 72C where it would have been 80-82C before.
I'm also staying away from those Gigabyte tuning utilities... D:
