Nebbers
System Specifications:
I. Processor/CPU:
Intel i5 2500k @ 4.6ghz
ASRock Motherboard (Z68)
8GB Patriot RAM
II. Current Graphics Card:
None - using the on-processor Intel graphics
III. Display Resolution:
1920x1080 for Windows
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications:
Corsair 430W Builder Series CX430
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent):
Antec Mini-Tower, ATX
Air cooled, 3 case fans
Purchase Details:
I. Budget
I'm looking to spend the absolute lowest amount possible for reasonable performance. I will not be gaming all that much, but would like to try out a few things (namely Diablo III).
II. Any particular preferences?
Not really. Open to whatever.
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
No
IV. Have you previously looked at a product(s) which you feel would fit your needs?
A bit, but don't really know what's what right now.
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
Diablo III
Not sure what else. I don't need 100 FPS at max settings in every possible game, just a decent enough card to play anything currently released without slowdown.
VI. Do you plan on overclocking the card you intend to purchase?
Probably not. Maybe, if it's a card that overclocks very well.
I. Processor/CPU:
8GB Patriot RAM
Purchase Details:
I. Budget
No
Diablo III
