RussianSensation
- Sep 5, 2003
- 19,458
- 765
- 126
Well in the short term, a 4-core 2500k with overclocking is pretty much the best bang for the buck for now, but if you intend to keep your system for 4-5 years, who knows. Maybe by that time the 8-core BD may actually be way faster as games start to use 6-8 threads (in 2016). The other alternative is instead of buying parts to "futureproof", it's far more effective to buy mid-range parts and sell more frequently.
Not sure what videocard you have now with the P4 but for your new build, but I am guessing you won't be reusing it? Either way, don't get a $450 GPU and "hold" it for 5 years. That's a losing strategy. You'll be FAR better off getting an HD6870 for $150 and then upgrading to another $150 GPU in 2.5 years and then another $150 GPU in 2.5 more years. That's why I think you should spend a little more on the CPU given your reluctance to upgrade often. With a fast CPU (at least a quad), you'll be able to upgrade 3 GPU generations without worrying about your platform. 8GB of DDR3 is very cheap now ($50). So an i5-2400 and 8GB of DDR3 should be your starting point. I'd get the 2500k to give you a good headroom to overclock should you need 30% more performance in 2 years. Cap off at that $225-250 CPU price level and leave the rest for GPU upgrades.
