DietDrThunder
1. What YOUR PC will be used for:
The System will be a home office PC.
2. What is YOUR budget:
My budget is between $450 and $550.
3. What country YOU will be buying YOUR parts from:
USA - NewEgg, Superbiiz, Amazon, or wherever I can get the best deal including shipping.
4. IF you're buying parts OUTSIDE the US:
USA Only
5. IF YOU have a brand preference.
AMD-Fanboy, nVidia-Fanboy, Samsung-Fanboy, WD-Fanboy.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Reusing Samsung 1080p Monitor, Microsoft Gaming Keyboard, Samsung 500Gb SSD, WD 7200 RPM 4TB HD, Logitec Mouse, Cooler Master Silent Pro M700 ATX12 80 Plus Bronze Certified Power supply,
Windows 7 Pro, Microsoft Office Pro 2013
7. IF YOU plan on overclocking or run the system at default speeds.
I plan to run it at default speeds.
8. What resolution, not monitor size, will you be using?
Existing 1080p for now, but would eventually (within a year) upgrade to a 4K display.
9. WHEN do you plan to build it?
Within a month.
10. Justification:
I want this to be a small form factor PC with an equally small computer case. I'm thinking on the lines of a mini-ITX based system. I also want the motherboard to have on-board graphic and AMD Rizen based.
11. Possible components list in which I'd like feedback on:
ASRock Mini-ITX Motherboard - AB350 GAMING-ITX/AC
https://www.amazon.com/gp/product/B073BFTJQK/ref=ox_sc_act_title_4?smid=ATVPDKIKX0DER&psc=1
AMD Ryzen 3 1200 Quad-core (4 Core) 3.10 GHz Processor
https://www.amazon.com/gp/product/B0741DN383/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=AZCEI3EMXUPTH
G.Skill Ripjaws V 16GB (2x 8 GB) (Dual Channel Kit) 3000MHz DDR4 288-Pin DDR4 SDRAM Desktop Memory (F4-3000C15D-16GVR)
https://www.amazon.com/gp/product/B013J7L6BM/ref=ox_sc_act_title_3?smid=A2D1YQFFOF9GHP&psc=1
Cooler Master Elite 130 - Mini-ITX Computer Case
https://www.amazon.com/gp/product/B00DJ6A88G/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
If my ATX power supply will fit in the new case, I'll reuse it. Unless of course you guys su a better option
USA Only
Within a month.
10. Justification:
