Yes, the mod initially jumped the gun. Technically doable since you did "bump" your thread, but personally I'd wait until it had happened a time or two before I even considered a lock down. Much easier to just send a PM to you saying "lay off the self-bumpage, eh?" Likely the mod in question realizes this and may consider the case in the future when policing the FS/FT board. People make mistakes. That's ok.
That being said, taking it like you did and responding the way you did was, how shall I say... "less than choice". By putting up a stink on so minor an issue, you validated the mod's initial response. Seriously, for the most part we the users have next to zero power around here. It makes zero sense to try and throw your weight around. Your thread's locked? Zap of a PM to get clarification and see how you can keep things on the up and up.
"I will protest in silence" = You're not going to get what you want. You're not going to get the result you want. You want vindication, you want validation, but what you
need is to just let bygones be bygones and get over it. You can easily repost the thread and start again. It's a damned online forum with thousands and thousands of members.
With that being said,I will not post here any more.I will not be part too hipocrites.If my post is not removed,I will edit it myself.The traders have been great,it is just the anonymous ones I worry about.Good day
Holy drama queen, batman
😉 Dear lord man, lighten up. I'll say again. It's an online forum.... In the grand scheme of things it just doesn't matter.
I say erase this thread, forget it ever happened and just get back to the trading you wanted to do. No one will think the less of you, we'll all hug and go our separate ways. There are no points to be had, face to be saved and no one is going to give you martyrdom credit by stepping up to say you're not going to say anything (Huh?!
