Originally posted by: SP33Demon
What's the diff between Snatch and squat? Also, it did look like u lost form and used your back although u said u did that on purpose...
330 lb squat is about what can do 2 of, I rep on 3X6@285 cuz deep squats hurts the knees. Rep on leg press@ 950 lbs, max bench press is 335, rep on 275. Oh can't forget deadlift, repping 315 atm.
Squat was what you saw me do:
http://homepage.ntlworld.com/ph.chea/Koing%20150kg%20x%202reps.wmv
Snatch is th is:
http://homepage.ntlworld.com/ph.chea/Koing%20Snatch%2095kg%20Pass.wmv
Snatch is a totally different lift.
Form was good. Back stayed straight throughout the lift. Yes the angle of my back changed but my back did not round. Thats the main thing. As soon as your back rounds our back takes a lot of the stress. But if your back is straight you are good to go. You probably notice the
hip drive forwards. Well that makes the squat easier. You see once I am off the bottom and my hips start to drive in I move faster? Well thats the purpose of putting the hip in forwards.
As soon as your hips are under the bar you are in a stronger position. The leverage is better the sooner your hips are under the bar. Remember this is different to a PowerLifting squat where they sit back much more and bend more at the hips and lean forwards and the bar is lower down on the back. They go to parallel for their competition rules so they train to do that. Only makes sense.
The 2nd rep was slower on the way up on the 150kg but form was good. Stayed tight.
Your BP kills mine. I haven't BP in about 4 weeks. I'll do some tomorrow but I've just been really focusing on my OL so not done much of BP or anything else. Your squat is good. How come your knees hurt? Bad form when you knew less or injuries? You know the leg press doens't count
. Too dependent on the type of machine you use and where the levers are. But with a normal squat or DL it is all the same :beer:
Koing
(sleep now so will reply later)
Thanks for the info on the snatch... It looks dangerous! Especially with so much pressure on your wrists on the lift, and keeping your arms locked and bringing it back over your head (analogous to how I cringe every time I see someone doing military press behind their head instead of in front). Neat though, is there a competition for snatch? Olympic event?
Well as long as your back stayed straight. I do the same thing on my squats sometimes when my quads give out, I use more of my back to get that final couple of reps up.
Got bad knees from running varsity winter track (sprints in 55, 200, 400m). Sprints really take its toll on you, especially with a stocky build (5-6, 200lbs)! Yeah legpress isn't as effective as squat, but it's cool to brag about (especially to the ladies, they're :Q when u say "950 lbs" lol).
Bench is high, but I get injured alot on it... for some reason, the top of my left shoulder loves to get injured. I'm probably going to start benching with more of a closer grip so I go a little lighter, as well as train light every other week (I go heavy@ALL TIMES). Eventually it starts to wear on your joints/ligs I presume.
