Originally posted by: Crucial
spider?
Damn this thing took off!
I haven't posted because I've been busy moving into the home I bought that is the cause of this question.
Basically, I have in my living room a cat 5e jack with my standard rj11 jack for phone pulled to basically behind where the couch sits, the issue is that it's on the opposite side of the room that I need it.
The home is pre-wired to a few rooms but what I want to do is get a cat 5 cable down the wall on the other side to come out by my coax since I need a wired connection for my media center.
All the cat 5 for the house runs through the attic and then down the walls to each room and all comes back to a patch panel in the garage. I was just trying to see if there was an easy way to jump off of one of those cables so I don't have to do a full home run pull for the additional connection I want and since it'd be in the attic that I would have wanted to do that split, I wouldn't have had access to a power outlet for a switch.
But I've come up with an easier solution of just pulling up the cat 5 from the master bed room and then dropping down the wall I need it for in the living room since I have the home covered in wi-fi and have no need for a wired connection in the master bedroom.
