Originally posted by: johngute
so can i underclock my power to save energy? like turn it down to 10hz when i'm not home.
Originally posted by: Special K
If you were to increase the frequency, wouldn't many things actually run slower as a result? Electric motors can be modeled as inductive loads, so since Z = jwL, the impedance would increase, resulting in less current being delivered to the motor.
That's my quick mental analysis anyway.
Originally posted by: shadghost
(if you all did not figure it out he was jokeing....... but could bulid stuff to do this)
Originally posted by: angminas
Build a robot that flicks your main breaker off and on 90 times a second. You get used to the noise.
Originally posted by: Eghck
MY CPU IS COLD WITH SOLUTION!!!!
Originally posted by: Mrfrog840
stick a fork in the electrical outlet and turn it up.... 😀
Originally posted by: everman
You'll need a better cooling solution, I suggest water in the power lines.
Originally posted by: slackwarelinux
Originally posted by: Molondo
Shake your Outlet, see if that boosts your power.
So you are saying if I shake out all the stuck electricity, then it would run faster?
Wouldn't it be easier to just use compressed error?
