Originally posted by: pkme2
Since the PC-60 is all aluminum and has a mobo tray, heat dissipation is excellent.
So Howard, you don't believe in the properties of Aluminum over Steel.
Let me know in your infinite wisdom what you think what I said is wrong.
The mobo fits on an aluminum sliding tray in an aluminum case.
This setup doesn't help to dissipate heat? A floating mobo with excellent air circulation.
"How are these factors contributing to higher heat dissipation?"
Do I have to draw a picture? No a picture worth a 1000 words.
http://www.lian-li.com/Product/Chassis/...lassical_PC-6x_S/M_C_PC-6X_S_PC-60.htm
I always wait for your input. You always try to correct. Maybe you should stick to the facts.
