i wanna sleep in quietness...
Idleuser
882
you can't cut 2 holes in the back to fit a 2x80mm fans... because the hold is right in the center... you can drill 4 holes to make a 92mm fit :) that's what I did witht he exact same case and remove the mesh grill in the front to reduce noise. I watercooled mines but it's not necessary to go with a quieter setup. what kind of setup are you running right now?
0roo0roo
64,795
84
i've dremeled 80mm grates off cases. its a good way to shore up a sh*t old case, but ur really wasting your time if you are going for silence. for the effort u still aren't going to match a single low rpm 120mm
