I think pearle vision cheated me
Status
Not open for further replies.
Sadaiyappan
1,120
4
Hi, I ordered 1.74 high index lenses and I got a rimless frame. My prescription went up a little bit (my prescription only went up +1 in each eye to -6.50 and -7.75). I'm pretty sure I got 1.67 or 1.71 last time and those are much much thinner than my new 1.74 glasses. My new glasses are more than twice as thick at the edges. I called them up and told them it seemed too thick, they told me the rimless frame means it will be thicker. Did they cheat me? What should I do?
Saga
Banned
Feb 18, 2005
2,718
Every Rimless frame I have ever ordered was thicker than rimmed glasses. I'm no professional, but I would venture to assume it's due to needing to put the band in the lenses to allow it to attach to the rim securely.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Of course they cheated you, it's pearle vision! That said, if your vision has been corrected and you see well with them, relax. Your life won't change because you have thicker lenses.
Mike Gayner
6,175
Why would they cheat you on this? Amazing they your first assumption is that they're being dishonest, when they are experts whose point seems completely rational.
Sadaiyappan
1,120
4
Okay good. I didn't realize they would be that much thicker. Guess I will go with half rimless next time.
techs
28,559
4
As I understand it, different lens materials will refract at different rates.
Depending on your lens material, your lenses could be thicker or thinner for the same refraction.
Ticky
436
If you measure the radii of curvature of the surfaces, you could calculate if it is the right index.
JEDIYoda
33,986
3,321
My rimless frames are thin as a peice of paper...of course my lenses are made from dilithium crystals...
olds
50,124
778
They cheated you by giving you MORE glass?
rudeguy
47,351
14
61
They screwed me hard last year. I got my exam, contact exam and ordered Air Optics contacts from them. When I picked them up, they were for ZERO correction. When I called them, they claimed that I didn't need correction even though I always have and the exam they gave me said I did.
I will never, ever, ever step foot in one of their stores again.
Kaieye
If the eyesize is bigger than the last old frame, they can be thicker. By the way, did the lenses come with Anti Reflective coating by chance?
FleshLight
6,883
Rimless requires them to drill into the lens so it maybe thicker. But I'd just order the lower index frame next time.
Status
