I think my CPU is too hot... I need help I think its gonna fry!
JackBurton
15,993
14
That might be one reason, I had a K7S5A before with my 1.33 t-bird and temps were around 50-55c. I switched to an MSI kt3 ultra2 and the xp1800 and my temps are steady around 40c. And before I used the stock AMD fan.
Yes, and I've taken that into consideration. However, if my readings were 150C I wouldn't really care as long as my system was stable. I'd assume it was just a bad reading. But in my case, I'm showing 52C idle, my heatsink is hotter than hell and when I run a game it hard locks pretty quick. When I'm just surfing the net or doing normal things within Windows it is super solid.
mechBgon
Oct 31, 1999
30,699
On my K7S5A, I get CPU temperature readings of up to 59C with a 1GHz Duron overclocked to 1.33GHz, which is approaching the 1.4GHz that your 1600+ runs at. Mine is one of the original-revision K7S5A's. Anyway, it runs quite happily at that temperature.
I wonder if your motherboard's chipset is overheating, since I have heard rumors to that effect with K7S5A's. I see in your other thread that opening the case and aiming a fan into it fixed the lockup problem, so keep this in mind as a possibility. While you're waiting for your Alpha to arrive, maybe you can test this theory by putting a little fan on your motherboard's heatsink, if you have one lying around.
gwlam12
6,946
um...my tbird 1.4ghz is running at 60C while system temperature is at 50C. im on an msi k7t266 motherboard. do i need a new heatsink? i have a coolermaster that came with it
Bleep
according to this site, the max temp on the XP1800+ is 90C
I do not see anywhere on that site where it gives the max temp for any CPU. It only gives the case temp.
I have one that runs about 60 with 100% CPU usage but with the case side off it runs at 56 and I think that is plenty cool for a AMD processor.
Dont Panic.
Bleep
gwlam12
6,946
oh im not worrying. i wanna overclock, but cant get it anywhere past 140fsb (while the rest of u guys are at 150+fsb), which is 1.5ghz for me.
eno
864
I am running the Thermalright SK-6 heatsink with a cheap Antec 80mm case fan and I run at 44c max. I have artic silver on it and very good case cooling.(3x 80mm in / 2x 80mm out / PCI fan out ) I have my Xp1600+ OC to 1900+ at 150fsb. If I go to 152fsb I get lock ups.
