Tempered81
- Jan 29, 2007
- 6,374
- 1
- 81
Originally posted by: ShawnD1
Originally posted by: arkcom
My first home-built pc had a 1700+ in it. Easily hit 2400+ on air. Don't remember what I got with water. That thing was about $60.
This is one thing I'll never understand. Someone will buy a $60 processor, cool it with a $250 water cooling system, then overclock it to match the speed of a stock $300 processor.
People still do that. They'll buy Intel's E5400 for $90, cool it with a $70 heatsink, then pray to god they can match the performance of a Q8200 which costs $165 and includes a heatsink.
Because that water cooling system easily carries on to the next $60 cpu and the next.... Plus my whole water setup was about $100.
Edit: you can get a Zigmatek HDT-S1283 for $32 and it's in the top 5 best hsf out there.
another edit: Why would an OCer buy an e5400 over an e5200?
Originally posted by: dguy6789
What about the mobile Bartons? Could take those babies to 2.5Ghz.(Which was a LOT at the time for an Athlon XP)
Originally posted by: rchiu
Nope, not even close. I had TWO celeron 300A in dual slot mobo and OC'ed to 466. Wake me up when I can do that with i7.
Originally posted by: SickBeast
Originally posted by: fffblackmage
I was too young and computer illiterate to know about the 300A =/
My first successful CPU overclock was with my 2600+ barton, 1.9GHz stock to 2.3GHz on 2V. Though that was because I was getting my new C2D and didn't care about possibly frying my old barton. nForce2 mobo ended up dying first instead (when exploring underclocking/undervolting, oddly enough). T_T
It was probably dormant, not dead.
Originally posted by: Mwing
my Barton 2500 couldn't make it to 3200 speed![]()
Originally posted by: Insomniator
Yeah, I also just looked it up and even the 2500 only cost 100 bucks at launch.... hmmm thought stuff was more expensive back then...
$100 is more reasonable for water cooling, but you can still only use it for the socket types it was designed for. When a new socket comes out and the mounting bracket is different, tough luck.
One might buy the 5400 because it has a higher multiplier. It will hit much higher speeds before you need to worry about motherboard crapping out at that 20-30% limit I've seen on every motherboard I've ever purchased (probably because I never replace the northbridge fan with something better).
Another issue is that "good" processors often have things you can't get by simply overclocking a slower processor. This could be something like hyperthreading on the i7 but not on the cheaper core 2 quads. Another common one is L2 cache - expensive chips have it and cheap ones don't. More recently, this also extends into the shear number of cores the processor has. If I have $100 to spend on a processor, is it better to buy a Phenom X4 9600 with stock cooling or to get a Kuma X2 7750 with a really good heatsink? Sure the X2 will overclock way higher and get much much better performance from single and double threaded applications, but it will fall flat on its face when you throw anything at it that can use 4 threads, or if you try running more than 1 program at a time.
It seems like a lot of good overclocking processors are bought on the assumption that you can't overclock the more expensive ones. My E6600 was a top of the line processor when I got it and it's currently overclocked 25% on stock cooling (bottlenecked by the motherboard), so let's use that 25% as a baseline expected overclock. If you buy a $70 E5200 with a $32 cooler, do you expect it to overclock to be faster than the processor that is one step up, overclocked by 25%? In this case that would be the E7xxx line. I would guess that no it probably won't, but that's my bias.
Another common one is the E8400 for $168 on Newegg. It's so popular that it has over 2300 comments and it has a customer choice award. If you threw on a $32 cooler to bring the price up to $200, do you think that would be faster than a 20% overclocked Q8300 for $190? Again, I'm not sure. I would guess the quad core is better, but I could be wrong.
The e8400 would dominate many benchmarks against the quad. Hell, even a good e5200 @ 3.8-4.0 would. This is especially true for games, but this argument has been done and done. Soon, yes, the quads will take over but not quite yet...
Originally posted by: aigomorla
i still think the A64 was the greatest overclocking chip.
It set new standards on how well a chip should overclock.
Then again the C2D also spoiled the CRAP out of us... hello, getting a E6600 2.4ghz processor to 3.6ghz like a piece of cake.
Shiet.. gillbot has my old X6800 that does 4ghz, and he's scratching his head going WOW, this was possible in 2006?
Mmm...the Celeron was much cheaper in its day. The i7 is not all that affordable. Yeah, it does the OC, but IMO the truly great OC chips are low end ones that match or beat the top of the line chips. The i7 is not this. Intel has created their product lineup to prevent another Celeron 300A from ever happening again. We need to hope AMD does not do the same.
Point is a sub $300 cpu can perform as good as one costing $1000 on stock cooling. Add the cost of a decent cooler and you have a good shot at 4GHz which no cpu out of the box (no o/c) can currently touch. The stock to o/c ratio is very similar as well.
Originally posted by: Idontcare
Who knew such a light-hearted analogy for recognizing what one can do with an i7 920 would invoke such a defense against attempting such recognition. Like it was really intended to generate a debate.
The OP owned many 300A's, if she wants to conclude in her opinion that a 920 today is like owning a 300A 10yrs ago then who is to stay her opinion is wrong/invalid/misplaced?
She's speaks from firsthand experience, reading this thread and the nitpicking it incited in some folks I really have to wonder if they personally owned either a 300A or an i7 920.
