I think I was just exposed to mercury
boomerang
18,883
641
Originally posted by: nater
people used to play with that stuff. You'll be fine
Me being one of those. Hours of fun!
I've got a ton of fillings in my teeth. Mercury there too.
Mark R
16
Probably, the most sensible thing to do is to get out and open the windows, but close the doors and allow the dust to settle or go out of the window. Then 24-48 hours later clean up the glass and dust as best as you can, preferably using a wet cloth. Don't use a vacuum cleaner, as it will just stir up the air, and the powder is so fine that it may not get trapped in the cleaner. Try not to use a brush, except for the little bits of glass that you can't otherwise pick up.
Fluorescent lamps of all types contain mercury - although the more modern ones contain only the absolute minimum needed to function. Tubes made in the last 3 or 4 years, contain less than 5 mg, and often contain below 3 mg - although older tubes may have contained over 20mg.
Squisher
21,204
66
You guys laugh but federal guidelines for broken bulbs are pretty stringent.
What to Do if a Fluorescent Light Bulb Breaks
Fluorescent light bulbs contain a very small amount of mercury sealed within the glass tubing. EPA recommends the following clean-up and disposal guidelines:
Open a window and leave the room for 15 minutes or more.
Carefully scoop up the fragments and powder with stiff paper or cardboard and place them in a sealed plastic bag.
Use disposable rubber gloves, if available (i.e., do not use bare hands). Wipe the area clean with damp paper towels or disposable wet wipes and place them in the plastic bag.
Do not use a vacuum or broom to clean up the broken bulb on hard surfaces.
Place all cleanup materials in a second sealed plastic bag.
Place the first bag in a second sealed plastic bag and put it in the outdoor trash container or in another outdoor protected area for the next normal trash disposal.
Note: Some states prohibit such trash disposal and require that broken and unbroken lamps be taken to a local recycling center.
Wash your hands after disposing of the bag.
If a fluorescent bulb breaks on a rug or carpet:
First, remove all materials you can without using a vacuum cleaner, following the steps above. Sticky tape (such as duct tape) can be used to pick up small pieces and powder.
If vacuuming is needed after all visible materials are removed, vacuum the area where the bulb was broken, remove the vacuum bag (or empty and wipe the canister) and put the bag or vacuum debris in two sealed plastic bags in the outdoor trash or protected outdoor location for normal disposal
http://www.epa.gov/mercury/spills/#flourescent
sdifox
100,849
18,071
It's not that bad... you consume more mercury than that from food.
Anonemous
7,361
wasn't there a story a while back about a lady who had to pay thousands since she broke one of these bulbs and they had to quarantine her home or something?
SearchMaster
7,791
114
The EPA also wants me to call them if I'm filling my boat with gas and spill more than a few ounces.
NanoStuff
Banned
Mar 23, 2006
2,981
You should see their guidelines on safely disposing a can of tuna.
SampSon
7,160
I have jars of liquid mercury sitting in my basement. We used to tool around with them at times.
You should be more worried about being exposed to sunlight, or car exhaust.
FoBoT
63,084
15
fobot.com
a little mercury never hurt nobody
unless you bathe in it for a few weeks or inject it into your muscles, it isn't that bad
boomerang
18,883
641
Injecting - like in immunization shots?
Nyati13
785
Originally posted by: joshsquall
Originally posted by: Gamingphreek
Originally posted by: WombRaider
Originally posted by: Tobolo
How old was this light bulb? When in hades was the last time mercury was in a standard light bulb?
It wasn't an old light bulb. I was putting in a fluorescent bulb which contains mercury.
I really don't think a fluorescent bulb contains mercury man. What happens when you throw it in a dumpster and it shatters- sorry but everyone around there isn't screwed.
You must be thinking of something else.
-Kevin
Fluorescent bulbs do contain mercury. Those compact fluorescents you buy to save the environment? Yep, mercury.
A lot of the electricity that the CFLs can save is produced by burning coal. Coal exhaust contains dramatically greater amounts of mercury, and as an added bonus uranium, than the CFL contains.
imported_Imp
9,148
As a stupid little kid, I once bit down too hard on a thermometer and broke it. Thing exploded in my mouth...and I'm fine.....right? The important thing is I'm not dead. Retarded? Maybe.
SVT Cobra
13,264
And this comes from the same people that say I'll die if I eat that great orange flavored toothpaste. Those liars.
zerocool1
4,486
femaven.blogspot.com
linky
Aware that CFLs contain potentially hazardous substances, Bridges called her local Home Depot for advice. The store told her that the CFL contained mercury and that she should call the Poison Control hotline, which in turn directed her to the Maine Department of Environmental Protection.
The DEP sent a specialist to Bridges' house to test for mercury contamination. The specialist found mercury levels in the bedroom in excess of six times the state's "safe" level for mercury contamination of 300 billionths of a gram per cubic meter. The DEP specialist recommended that Bridges call an environmental cleanup firm, which reportedly gave her a "low-ball" estimate of US$2,000 to clean up the room. The room then was sealed off with plastic and Bridges began "gathering finances" to pay for the US$2,000 cleaning. Reportedly, her insurance company wouldn't cover the cleanup costs because mercury is a pollutant.
keep that in mind...
