I think I got a virus from a USB device; need help
vollman1
62
First, is this possible? The device was a Lego Mindstorms unit that can be programmed from the PC via a USB link.
If it is possible, could the virus have infected my Logitech G500 mouse which is also programmable?
I really don't want to infect another computer.
VirtualLarry
56,587
10,227
Does the Lego mindstorms unit appear as a USB Mass Storage Device to the computer?
If it does, then it potentially could get infected.
A USB mouse, unless it also shows up as a Mass Storage Device as well as a mouse, then no, it cannot get infected.
nalooh
Since virus will be triggered the moment you open your flash drive, I suggest you do it first on the command prompt. You can see the open your files here, without waking up the malware, and delete the virus.
