heh I don't post for a day, so now I have to address everyone starting from NFS4's comment "So you're saying that the athlon/Thunderbird/Duron is trash???"
Yes, considering how well they can make it right now. Look at it this way, it has 1/3 more potential processing power/clock then the Pentium 3, because it has 3 pipelines, and 128 K L1 cache, coupled with now 256K L2 cache with a bit of a bottleneck..
the L1 cache is fine for the 3 pipes, the L2 cache needs a bigger interface with the CPU, they need to get that core pushed to the max, like Intel has with their Pentium series (I highly doubt they are hiding anything in that CPU). If they went as far with the Athlon as Intel has done with that old core, the Athlon would live a longer life then it will in their roadmap (with the Sledgehammer coming up fast). I don't like how they are handling the Athlon, but also, I don't like how they are going to drop it and run with the Sledgehammer (with the K7 core probably in the low end like the K6-2 was until recently).
you understand my rant NFS4?
pm, "Bear in mind that I work in the IA64 group and so I know a fair amount on IA64 products, but very little about IA32."
Does this mean you can tell me anything about if Motherbaords will be different? I mean using IRQ's and the such?
"In fact, most of the time the Register seems to know more about our future products than I do" heh, those of you who think the Register sucks, think again! this guy's an insider!
Dreamer, "I am glad AMD made a better chip and finally improved their supply problems, but this talk about the Mustang being what the Athlon should have been is lame, the Athlon should have came in and just rocked."
Yes you are right. Then the marketing and stuff occurred, where AMD had to make sure that it would go on a Slot, and therefor thought it would be fine with the limited speed cache, becuase they doubted intel's ability to go .18 and increase the P3 line to over 600mhz.
The company decided to use this strategy; the Mustang will be what the Athlon should be, becuase we need all the money we can get.
So they MILKED it by releasing lower performance, but competitive versions of their Athlon.
The athlon still has potential, it's just that the COMPANY came before the product, and therefor the company survived with more money then if the product came before the company, which leads to better products down the road becuase of better R&D.
AMD is smart in that they are looking in the long run. even in the short run, they are doing mighty fine with these CPU's.
The mustang will be what the Athlon should have been, and will go up against Willamette, in mhz, and in pure speed per clock.
Bobberfett - "The power of the EV6 bus will become apparent when DDR SMP motherboards become available. You'll see Athlon servers and workstations that will quite literally destroy any Intel setup."
True, but the Willamette will have a Quad pumped FSB, and if Via doesn't do anything about their PCI bus at 133 vs. Intel's bus at 266, there will become some problems in speed. With the DDR chipset, Via will hopefully be using a new northbridge which might allow the use of a new Chipset Architecture. we will see.
to AMD's advantage, the EV-6 Bus can supposedly go up to 200mhz, which when using DDR is as fast as Intels planned FSB.
