Let's discuss the differences between refresh rates for people that DO NOT PLAY ANY FPS GAMES. I hate FPS games like Call of Duty, so I can't comment on those.
I see no difference between 60Hz and 120+hz. Am I simply crazy? I checked this with RPGs like Fallout, Baldurs gate, and Encased. I also play RTS games such as Warcraft 3, Starcraft 2 and Warhammer 40k: Dawn of War.
No you aren't crazy. Probably the reaction of most people if they don't get caught up in hype.
I just upgraded from 60Hz to a 165 Hz panel.
IMO, the difference is greatly exaggerated, and mostly discernable in test cases.
To be clear. I can see the difference if I do some kind of test case.
Test Case: Blur Busters
If I do the blur busters UFO test. It's very
obvious that 120 Hz is much clearer than 60 Hz. Though any difference between 120 and 165 is so negligible, that I'm pretty sure I would fail an ABX test between 120 and 165, so would never upgrade for even faster.
Test Case: Desktop Mouse
Whip around mouse on desktop. This is often cited as proof it's much better. Higher refresh and the pointer breaks up into more image points, lower refresh you get less segments. But other than breaking up into more segments, it actually doesn't feel any different when just moving it around normally.
Test: Gaming
Most of the games I play are older, and are frame limited, or wrong genre, so far I haven't been able to see a difference. This is probably mainly a benefit to FPS esports gamers which I'm not...
Anyone care to suggest an open source game game where I can test? I'm not buying a game just for testing, nor will I install any new gaming stores (I'm GoG only).
Edit: Found I have Metro Last Light Redux in my GoG library. Tried that, and really I don't see any significant difference between 60 FPS and 120 FPS.
