I am a little confused about how WINS works.
I got this froma web site; "Q. What is WINS?
A. WINS stands for Windows Internet Name Service. WINS is a NetBIOS Name Server that registers your NetBIOS names and resolves into IP addresses.
If you're using NetBIOS over TCP/IP you will need to have WINS running so that each can find out the correct IP address of the other to communicate."
I understand that this service is needed so that computers on a network can be found but I don't inderstand when they say, "If you are using NetBIOS over TCP/IP you will need to have WINS running so that each can find out the correct IP address of the other to communicate." Why would you need to use NetBIOS over TCP/IP and vice versa???
Thanks for your help.
