I need to understand LAN card size!
ithehappy
540
4
Hi, two days back my motherboard's Ethernet port got dead, due to a bloody lightning/thunderstorm! It's a Sabertooth X58 board. I don't know what was the in built LAN card!
Anyway, I'm in market to buy one, buy I'm confused about size. I have GTX970 installed on my PCIEX16_1 slot, and the bloody big card occupies huge amount of space, so basically the slots above and below it are totally unusable, the top being PCIEX1_1 (small black one), and the bottom being labelled as PCI1 (bigger white one, without any lock clip), so those two slots are blocked, and even the PCIEX16_2 slot is almost blocked, I never did care about SLI anyway, so never bothered.
So the only two slots which are actually left to install something are the PCIEX1_2 (the small black one again) and the PCIEX16_3 (the big black one with lock clip), but even then the bottom one touches my PSU, LOL. I have a small cabinet by the way, CM 690II Plus. So is there any LAN card which will fit in that small PCIEX1_2 slot?
I have plan to buy this, http://www.amazon.in/TP-Link-TG-346...3e-6b9f-4e87-8559-cc17f62feccb#productDetails
Will that fit in the required slot?
MrTeal
3,901
2,632
Yeah, sticking it in PCEEX1_2 will work fine. A Gigabit NIC only needs an x1 PCIe link to function, so you can use it in whatever PCIe slot works best.
ithehappy
540
4
Thanks mate. That's a relief for sure. Could you please tell me what's the difference between that card and this one, except the WiFi part http://www.amazon.in/TP-Link-TL-WN7..._cp_147_1?ie=UTF8&refRID=0BFQKYEPHY5AGQSVF8XE
And also do you think that this card will work decently as a replacement unit in comparison to whatever my motherboard's built in was?
BurnItDwn
26,280
1,787
Honestly, for 99% of home use, any 100mbit or gbit ethernet card will meet all your needs.
PCI express ethernet is going to be the most modern/cutting edge with the best bandwidth and lowwest latency, but, you could use a USB Ethernet adapter if you wanted to.... (might be easier/cheaper for you)
The one you linked is a wifi part. For normal lan, maybe you meant to link this? http://www.amazon.in/TP-Link-TG-3468-Gigabit-Express-Network/dp/B003CFATNI
ithehappy
540
4
Thanks mate, no need to think about quality then, which is always a worry for me when I go for non-original vendors.
I actually linked the normal LAN version in my original post (the same one you linked), and for my last post I meant that WiFi one only, I am asking what's the difference between those two, the LAN only version and the one which comes with WiFi additionally? I mean other than having WiFi on my desktop is there any other difference between the two?
