I need to adhere a piece of glass onto a hardhat.
simms
8,211
The hardhat is plastic and the glass, well, is glass.
The hardhat is rounded so it won't make a complete seal against the glass which is flat based.
Ideas? Crazy glue?
It has to hold against people trying to steal it from me.
ElFenix
102,396
8,559
a big glop of 5 minute epoxy
wtf? suse920's post was here and now its gone!
edit: must be a mod lurking around :thumbup;
sharkeeper
10,886
Belzona will work.
That is not readily available to the public so PC-7 will probably be your next best bet. Both solutions are epoxy based. Be sure to sand the HH surface well, rough it up real well or better yet drill a few small holes and make sure the paste oozes through these holes to increase bond strength. The glass just needs to be cleaned and free of oil.
simms
8,211
Originally posted by: HappyPuppy
A hot glue gun will do it. Cheap and easy.
I should also mention it'll undergo serious stress tests, eg: people grabbing it by the glass to rip off my hardhat and steal it away.
Just want to make sure it's durable, not sure if glue guns will cut it.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
121
Back up here...lets forget the "HOW" for now and concentrate on the "WHY"!
hypn0tik
5,866
Most likely University. I know exactly what he's talking about. Stupid artsies.
simms
8,211
FTW!
I'd try an epoxy or silicone caulking. You could also etch the glass a bit to help...
How etch? It's concaved.. and the hardhat is convex.. which would make it ok, but they're not the same curvature.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
121
Originally posted by: Gobadgrs
and what do you do when they break the glass in their hands and get blood everywhere?
If he's an artsie, he will make a painting with the blood.....d'uh.
simms
8,211
Hmmmmm, where do you go to University?
;) UT
Why? Because artsies will try to take it from me! :shocked:
Good stuff. What program and year?
I'm Nsci OT7 btw.
Really.. I'm Chem 0T7. You leeduring this year? :)
simms
8,211
Their problem.. why the hell are they assaulting me? :p
ThisIsMatt
Banned
Aug 4, 2000
11,820
FTW!
A diamond, diamond cutting disk/bit/grinder, or even some synthetic jewels will cut glass easily.
