I need some suggestions on an SSD. EDIT: I need help imaging to SSD
Saffron
130
I ended up just doing a clean install. This is my first solid state hard drive and all I have to say is holy mo fo'in shizzle this thing fast!!! I'll be hard pressed to ever have a mechanical hard drive as my primary again!
Now I just need a 512gb for all my games lol.
Charlie98
6,298
64
I'm doing the same thing at the moment... I'm migrating from my 64GB primary drive to my new 256GB drive. I decided to do a clean install as well... it's a pain in the pahookie, but I think it will be worth it in the long run.
sze5003
14,320
683
If you keep only windows and a couple of apps its not so bad. I hated when I had everything on my mechanical drive and it needed formatting.
Charlie98
6,298
64
I have everything split between the 64GB and a HDD... My intentions are to roll it all up on the bigger SSD.
Bill Brasky
4,324
Let the addiction begin! It's an expensive one..
tweakboy
9,517
www.hammiestudios.com
Results with my 840, mostly filled drive.
My M4 pownz at seq Read. Thanks to 512k cluster size and 040H firmware.
Puffnstuff
16,252
4,927
When I migrated from my adata s599 128gb to my 256 gb samsung 840 pro I used acronis to move to the larger drive. It handled the partitioning so I didn't have to do a clean install.
