I NEED HELP! GTX 980 vs R9 390X
Status
Not open for further replies.
Spanners
325
Another vote for 970 / 390 or even 290 if you can find one (sometime 290's are found at around $200). GTX 970 and R9 390 are excellent cards for 1080p and will be able to push 60fps on GTA 5.
Agreed, by the time the 970/290/390 is unplayable most likely the 980 will be also. Seems to be the historic trend since I've been following the dGPU market. The performance increase now just doesn't justify the cost increase IMHO.
Save the money and spend it once second generation 14nm has arrived and all the DX12 chips have fallen.
Headfoot
4,444
641
Yeah GCN has scaled better than Maxwell in actual FPS per % overclock for quite some time now, as long as you're calculating "max boost clock" vs gcn fixed core clock. Maxwell scaling is about the same if you calculate from "actual measured clock speed" as opposed to "max boost clock" since the cards aren't going to always run at max boost clock.
OP: get a 290/290x/390 or a 970. I wouldn't spend all that extra money to get a handful of frames when you're already running over 60 fps in GTA V.
Black96ws6
140
You really can't go wrong with any 290x/390/390x or 970/980.
Here is a recent review, only a couple months old between a 290x and a 970. As you can see, with current drivers, at 1440p, they're very close:
http://www.hardwareheaven.com/2015/06/evga-geforce-gtx-970-review-ssc-edition/
I wouldn't recommend spending $400+ on a 980/390x when you can save a hundred bucks, get an aftermarket 290x/390/970 card, and OC it. Heck even at stock speeds the aftermarket cards will give you what you're looking for.
Probably not a good idea to spend $400 at this point anyway with new graphics cards on the 12-18 month horizon...
Dec 30, 2004
12,553
12,553
I would get either 290x or 390. 390 will give you 8GB VRAM which might come in handy, or the 290x will give you more performance right now and you can upgrade in 2 years if 4GB is a problem.
showb1z
462
53
I just got a 390. It's similar in price and performance to a 970, but you're guaranteed not to run into 3.5GB RAM headaches later on. I wouldn't trust Nvidia not to drop the ball on GTX970 driver optimizations once Pascal comes around.
guskline
5,338
476
Snell, what are the specs of your computer? I.E. cpu, mb, ram amount, hdd and psu plus the make and model of monitor. It really helps posters to consider as much info as possible.
boozzer
1,549
18
it isn't about trust, it is almost 100% guarantee that nv would drop support for 970 once pascal releases. :twisted:
Carfax83
6,841
1,536
GCN scales just fine with OC, almost linear %. It's not any different to the 7950/70 or R290/X. GCN has always scaled near perfect with OC unless it's from a shill site.
http://www.guru3d.com/articles_pages/msi_radeon_r9_390x_gaming_8g_oc_review,26.html
I've several generations of GCN already, starting with the a 7950 that did 50% OC and gained ~45% performance.
Basically any website that doesn't agree with your preformed opinions is a "shill website."
So is gamersnexus a shill website as well?
Or Kitguru?
TechPowerUp?
And let's not forget the Fury cards. They scale even worse.
RussianSensation
19,458
765
But none of this assists the OP. Whether 980 or 390X scales better with overclocking is basically irrelevant for GTA V because the more overriding theme is that neither the 980 nor the 390X is actually worth spending extra $$$ on over an after-market 290/290X/GTX970/390 for this title.
I am surprised you still keep recommending overpriced cards like GTX980 (or 390X) after owning GTX580, 770 4GB and 980. Wasn't owning 3 very poor price/performance cards and having all the historical performance data not enough to see just how poorly they aged for the price? Surely, by now you should have come to a realization that spending 40-50% more for barely more real world performance doesn't actually help to future-proof for next gen games?
When looking at 4K performance to try to simulate next gen more demanding titles at 1080P-1440P, the 980 doesn't look good at all.
10598
It's more strategic to buy an R9 290/290X/970/390 as a stop-gap 28nm card and upgrade to 16nm 8GB HBM2 card next year or just go all out on an after-market 980Ti, unless of course a 980 can be found for $400 or below.
futurefields
6,470
32
The 980 wins in DX11 games but the 390X will win in DX12 games from what I've seen. So the 390X might be more future proof but the 980 will give more instant gratification.
AnandThenMan
3,991
627
You know what's amazing? How the 290X keeps showing itself to be the best value, a card that was largely panned throughout its life cycle. I don't ever remember that happening before.
Carfax83
6,841
1,536
The OP wanted to know whether to choose a 390x or a 980 for GTA V. I told him to pick the 980 based on:
1) The 980 is faster than the 390x in this particular game at stock clocks.
2) When overclocked, the 980 can achieve a 20% boost that will put it well beyond the 390x, and somewhere between the Fury and the 980 Ti.
And you keep assuming that everyone is a penny pincher RS. Not everyone cares about bang for the buck. Some people just want the fastest hardware they can afford, and the best experience...
You always seem to want to bring up my purchasing history in every discussion :rolleyes: I got 3 years usage out of my GTX 580 SLI, and I think I only kept my 770 4G SLI for a year before I upgraded again. I upgrade whenever it is convenient to me, and that's that.. There's nothing more to be said.
If you want to hold on to your hardware for 3 or 4 years, then go ahead. I don't care what you do with your money or what you spend it on.
Flawed reasoning, because you assume that the GTX 980 will be at stock clocks. Very few people buy stock clocked GTX 980s with reference coolers.
Aftermarket models with much better coolers can see a GTX 980 hit 1430MHz with automatic boost, making it considerably faster than the stock model. And this is before manual overclocking.
Also, future proofing is a ridiculous concept. Nobody knows what the future will hold. The only guarantee is that the next generation of cards will be faster than the current one.
The 980, like all the other 28nm cards don't handle 4K well, so using 4K to simulate next gen games is senseless..
3DVagabond
11,951
204
They are about even in DX11. We don't know for sure in DX12, but judging by the last couple of generations, it's more likely that the 390X will outperform the 980 going forward, than the other way around. History tends to repeat itself.
3DVagabond
11,951
204
Yeah, the review sites really screwed us over with Hawaii. They did everything they could to paint it in a bad light.
Headfoot
4,444
641
The reference ones always seemed like a classic tweakers chip. A great deal cheaper than the top end chip, but very close after you take the time to tweak it out (e.g. custom cooling and overclocking it). The stock cooler really did hold it back rather dramatically
The 290 is and has been for quite some time the 8800 GT of 28nm. I remember when even the 780 was more expensive. Look at how that turned out
RussianSensation
19,458
765
1. 980 is faster by nothing material that can be noticed without actually benchmarking the recording the data. AKA waste of $$$.
2. Stating that 980 can OC 20% and ignoring that 290/290X/390/GTX970 can also all overclock at least 15% is ridiculous. Also, your comment that a GTX980 OC ends up between Fury and 980Ti is also misleading since it takes a maxed overclock 980 just to match a stock Fury and since Fury can also be overclocked, 980 will ultimately be the slower card.
It has nothing to do with pinching pennies. Are you out of your mind to recommend that a gamer spends $150-200 more for a GTX980 over an R9 290X/R9 390/970 for 4-5 more FPS? Your argument lacks any logic because if you say perf/$$$ doesn't matter, then it makes no sense to recommend a GTX980/390X because might as well go all out for the 980Ti.
The reason I bring up your GPU history is because it shows a lot about your own advise to other members. You constantly pick cards that are in no man's land and then keep recommending them. The GTX580 I can understand but I believe you bought 580 3GB in an era when HD7970 mopped the floor with it by 40-80%. You bought 770 in an era when each 280X/HD7970Ghz was $150 less, meaning it cost $300 less to buy 280X / HD7970Ghz CF that actually were faster than GTX770 4GB SLI.
All that tells us is that you either have absolutely no grasp of calculating perf/$$$ or you just randomly buy graphics cards based on arbitrary budget you have set for yourself. For example, if you set a strict $1000 budget, you just pick any 2 NV cards that fit it and buy them. Most people don't buy graphics cards like that because this is totally illogical. Normally a person will look at some point of reference to see if their purchase actually makes sense. If they don't care about price/performance, they'll buy 980Ti/980Ti SLi and be done with it.
That's not the point. You would rather recommend a GTX980 over 390X but frankly both cards are a waste of $. There is no context in which either of them makes sense given the current prices of GTX970/290X/390 in the US. For people who don't care about price/performance, they go 980Ti (or Fury X). The extra performance of a 980/390X for GTA V over the cards I mentioned is literally money wasted because it will not improve the actual gaming experience.
No, I didn't assume anything. It's you who is ignoring that all over GPUs can also overclock and that cards like 290/290X/970/390 can already give the OP the performance he desires. Any extra tangible performance will only come in the form of a 980Ti OC as it has another 35-45% performance that will actually allow turning on more AA filters and grass quality to Ultra. 980 doesn't have any tangible horsepower to pull something like that off in GTA V over a 970 OC, 390 OC or 290X OC. So, yes, really, it's like taking $150-200 and flushing it into the toilet (or NV + NV's AIB's pockets).
Again, you keep ignoring the original topic and where other cheaper cards stack against 980 in this title.
Precisely why buying GPUs that sit in no man's land is a waste of $. It's not emotions -- it's pure mathematics. 980 will not be more future-proof than a 290X/390/970 so it's not worth buying unless the price premium is small (i.e., < $400). If someone really wants extra horsepower, they are stepping up to the 980Ti.
It's not senseless at all. The idea of using the most GPU demanding scenarios to try to simulate how the extra workload on GPUs will let them handle it has been used by gamers for many generations and it generally is very accurate. The point here is that 980's performance gets MUCH closer to the R9 290X at high resolutions and the gap becomes way larger between a 980 and upper-tier cards like the Fury/Fury X and 980Ti which means once 980 is required to handle even more GPU load, it won't be able to handle it any better than cards like 290X/970 or 390. Therefore, it's the textbook definition of a GPU that sits in no man's land given its ludicrous $150-200 price premium.
This is a textbook GPU upgrading strategy case of putting aside $150-200 NOT wasted on 390X/980 and buying a stop-gap $250-300 card and then using the $ saved to get a MUCH faster 16nm HBM2 GPU. You seem to have a very hard time getting these simple concepts since it seems if you spend $200-300 more for 5-10% more performance, you don't care.
Newegg = XFX R9 290X with lifetime warranty for $249.99 + $2.99 shipping.
Let's try this one more time: GTX980 costs $450 but it only has 12-15% more performance over a $253 290X.
http://www.sweclockers.com/test/21045-amd-radeon-r9-nano/15#content
The reason your advice is not backed up by any facts is because a 290X (or 390 or 970) will be more than enough for GTA V (I actually provided the data). I am not sure why you have such a hard time understanding how spending $150-200 extra for 4-5 more FPS is a waste of $.
Carfax83
6,841
1,536
Right, 20+% is nothing :rolleyes:
The AMD cards are comparatively poor overclockers as they don't have the TDP headroom that the GTX 980 has.. Also GCN does not scale as well as Maxwell does..
I posted several links demonstrating this..
The Fury is a dog at overclocking. You're lucky if you get 100MHz extra out of it. Also, a max GTX 980 is either slightly slower, equal or faster than the Fury depending on the game and the resolution.
A 290x on the other hand isn't going to be able to catch up with or surpass a Fury unless it's water cooled.
Tek Syndicate GTX 980 OC vs Fury OC (and he didn't even overclock the memory, which would have gained an additional 5-6%)
Toptengamer GTX 980 OC vs Fury
The OP stated his choice between a 980 or a 390x, and between the two, the 980 is the better option period!
If you want to convince him to get a cheaper option instead then by all means do so, but you can't fault myself or others for adhering to the OP's choices.
It's his money after all, and not ours.
If I had listened to your terrible advice, I would have gotten the 2GB GTX 770s instead which would have reduced my game enjoyment since it was right around that time that games were starting to easily surpass 2GB of VRAM usage on a regular basis.
If I would have listened to your terrible advice, I would have gotten the 7970GHz cards which had broken crossfire, plus also with AMD being constantly late on producing crossfire profiles for new games, or not making the profiles at all.
If I had listened to your terrible advice, I would have gotten 290x crossfire instead of GTX 980s after returning my GTX 970s, and I would have had to wait 2 fricking months for AMD to release a crossfire profile for the Witcher 3 that actually works, when NVidia had a working SLI profile on day one....and not to mention inferior performance where I would have to disable hairworks!
And you can't comprehend that cheaper isn't always better. You strike me as the type that constantly buys cheap stuff which breaks after a few months, and then you go back and buy more cheap stuff and continue the endless cycle.
I on the other hand prefer quality. I want a good experience, and I don't want to regret my purchases down the road just because I managed to save a few bucks..
If the OP had specified he wanted a bang for the buck solution, I would have told him to get a GTX 970 and overclock it to the max. But he restricted his choices between a GTX 980 and a R9 390x..
It's his money, he can do what he likes with it.
Are you telling me that the 980 Ti can gain 35 to 45% extra performance from overclocking? Are you nuts? o_O
The 980 Ti gains the same performance as the GTX 980, which is an extra 20 to 25% from overclocking. Ryan said in his review of the GTX 980 Ti:
The gains from this overclock are a very consistent across all 5 of our sample games at 4K, with the average performance increase being 20%.
I'm actually starting to wonder if you actually read any reviews of aftermarket models.:|
And you're giving the OP advice that he never even asked for.. He said his choices were the GTX 980 or the 390x, not the 290x, 390, or GTX 970... :rolleyes:
Again, anyone that believes in the concept of future proofing is a fool to begin with..
That's akin to saying someone that only plays their games at 1080p should buy a GTX 980 Ti, because it's more "future proof" for the games of tomorrow... One should always buy hardware based on current needs..
Sorry but that's complete nonsense. The only reason why the gap narrows between the GTX 980 and the 290x at higher resolutions, is because the latter has more bandwidth.. It's the same reason why the gap between the 980 Ti and the Fury X also diminishes as the resolution increases.
It has nothing to do with future proofing....which is really a retarded concept to begin with.
You assume the OP is like you, in that he's willing to put up with a diminished experience in the present, for some supposed better experience in the future from saving a few bucks in the here and now..
If you're willing to wait long enough, there's always going to be something cheaper and better coming around the corner. Nobody disputes that.
But not everyone is willing to sacrifice a better gaming experience in the present, just to save a few bucks. I want to enjoy my games NOW, not 6 fricking months from now.
GTX 980 OC can be as much as 25% faster than a stock model, 1500MHz on the core, and 8GHz on the memory..
flopper
739
19
or you wait 6 months, and then play games for 5 years with the same card.
I buy a stop gap today as I expect next years line up to be way more interesting for a pc gamer and myself than current offerings.
Status
