My wife just cracked the tank on our toilet. I know what is needed to be done to replace a toilet and since we have another bathroom downstairs, I'll install a new toilet tomorrow. My simple question is: what toilet is a decent one to buy at a Lowes or Home Depot? Or, is it worth going to a local plumbing supply place like Blackman Plumbing (http://www.blackman.com)? FWIW: when I redid my bathroom, a long while ago, we kept our non-water saving toilet because my plumber suggested that I wouldn't be happy with one of the water saving toilets. Now, I need to buy one and I figured that I'd ask which is a good one that is available 'off the shelf'.
FWIW: I try not to buy things from Home Depot because I find a lot of things to be sub-par in quality. Yes, you can buy a Weber grill at HD, but it does not include the stainless burner that you'd get if you bought it elsewhere. You can buy a Moen faucet at HD, but the valve is plastic instead of brass if you bought it at a plumbing supply place. So, I figured I'd ask about a toilet because I don't want to mess with things once they after they are 'done'.
Old thread revived by spammer.
admin allisolm
admin allisolm
