i need a place where they sell face plates
fire400
5,204
21
lookin' for an intel 865PE face plate
Supported front side bus speed: 800, 533, and 400 MHz
Integrated Graphics: None
Chipset: Intel 865PE Chipset
AGP Connector: AGP 3.0 (4X & 8X Speed at 1.5 and 0.8 Volt Only)
Memory Type: Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100); Note: Be sure to review important memory and system bus speed considerations before using this Intel Desktop Board
Max Memory: Capacity of up to 4 GB
Memory Slots: 4 DDR DIMM Sockets
Slots: 5 PCI
Audio: Integrated AC'97 Audio with ADI 1985 CODEC, 6-Channel audio, including S/PDIF on rear I/O
USB Ports: 4 from Back Panel, 4 from Internal Header - USB 2.0
HDD: Two (Master & Slave) ATA 66/100 connectors; Two Serial ATA (SATA150; 1.5Gb/s) connectors, Serial ATA RAID 0 & 1 (See What RAID levels are supported for RAID implementation details.)
On-Board LAN: Intel Pro/100 (100 Mb)
IEEE 1394a: One IEEE 1394a port available at rear panel, and two IEEE 1394a front panel headers.
JohnAn2112
4,895
Face plate? You mean the plate that fits on the back of the case where the I/O ports are?
amdhunter
23,332
249
You can try what I did 3x already. 2x it worked.
I just contacted their support via email, and ask how much it would cost to purchase a backplate for their motherboards.
Either they will:
1) Ask for your info and send it to you for free (MSI, ASUS both did it)
2) Send you instructions to contact their sales department (Gigabyte)
Can't hurt to try.
fire400
5,204
21
Either they will:
Can't hurt to try.
this is an Intel mobo, you really think so?
otherwise, I'm just gonna stick with my 865G faceplate, I'm no die hard fan of having a 'perfect' PC machine where the backside isn't perfecto comp, but I'll probably be having a gap where the Intel Extreme 2 graphics vid-15-pin used to sit out of, 'n stuff like that.
plus it sucks that the 865G had gigabit ethernet on select models, and this 865PE from Intel din' have the giga controller.
do you guys know if all 865PE makes are actually voltage adjustable?
WildHorse
5,006
that guy in V is for Vendetta might be done with his faceplate & let you have it
Iron Woode
31,368
12,857
your question has been answered:
go to a local PC shop and check out the hundreds they have sitting in a box.
Make a drawing of the one you require and start hunting.
how hard is that?
KrillBee
1,433
how hard is that?
funny, i hadnt thought about this idea. i guess i dont like asking for free stuff from shops, lol.
Madwand1
3,309
I had no luck with Intel getting a full-height bracket for my Intel server NIC. Don't sell 'em separately from NICs, can't buy 'em.
