I'm using Fireworks 4. Now I've made a cool looking logo which can be seen here. On the bottom right hand corner I'd like to add a little countdown to the release of the game (mid Nov). I can't figure out how to do this. Could anyone be so kind as to help me out?
The logo you posted as a sample is probably done in Flash. I don't know Flash well enough to tell you how to do it but if you look around for the the code to add to an instance you should be able to.
