Kamijou Touma
1. What YOUR PC will be used for. Gaming, some video editing and music editing.
2. What YOUR budget is. 1500-1700
3. What country YOU will be buying YOUR parts from. USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. I prefer Intel/ Nvidia.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are. I am planning to use my 4tb HGST HD, 500tb Samsung EVO SSD.
7. IF YOU plan on overclocking or run the system at default speeds. Overclock
8. What resolution, not monitor size, will you be using? 1440p or 4k haven't decided yet.
9. WHEN do you plan to build it? 1-2 months.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? Windows 10
Some things I would like 2 m2 slots on the motherboard with wifi and bluetooth.
A 1tb m2 ssd is a must.
16gb of ram
Cooler Master MasterCase H500 ATX Mid Tower Case is this a good case.
I was looking at this motherboard Gigabyte Intel Z390 AORUS wifi is it good. I like this motherboard because it also has the usb 2.0 for my mouse and keyboard.
16gb of ram
