Not exactly a camera, but it does have a lens on it and it may solve the issue:
'Murika!
'Murika!
Thanks for the suggestions guys, I have something to go on now. The LaView cam RossMAN linked might be what I need. How do you like the picture quality in low light?
As far as IR, I'm not going to point it perpendicular to the window's glass, so I don't think reflection is a problem, especially if I press it up against the glass.
My camera touches the window at a 45 degree angle and IR blinds it. I tried every angle. That's why I had to finally mount the IR on the other side of the glass.
On my neighborhood forum the sheeples are panicking due to a suspicious black person and they are all scooping up The Ring. Live streaming to your phone in 1080p 2way audio you can answer your door from outer space. It'll sync up to your existing home automation too. Not sure if it would work with Blue Iris.
https://ring.com/
Home depot: http://www.homedepot.com/p/Ring-Wireless-Video-Door-Bell-88RG000FC100/206048897
Some models have an indicator light that's very conspicuous when it's on, and if you tape over the lights, the IR mode won't work, because, you know...
'Murika!
Good to know, thanks. I'll definitely explore the separate IR array option.
