Question I may be building a new system soon, but not "cutting edge"
jose
2,079
I've been building systems since the 486DX days,, Used Intel almost exclusively for both myself and my customers. But if I had to build a new high end workstation, I'd use the 7800x3d w/ 64 gigs of CL30 ram. on an x870E based mobo w/ a thermalright phantom spirit 120 se cooler. I just built in Jan. a HTPC for my son w/ a i5 13600kf and wish I had paid more attention to the 13/14th gen problems. I did build an AMD Athlon system once but switched back to Intel. Nothing was wrong w/ the system , just wanted to stay w/ Intel + nvidia. I would not invest in a 12 gen cpu while there's a great alternative available.. 7800x3d + 4080 .
BoomerD
66,511
14,895
Flash the microcode 0x129 BIOS update and the 13600KF should be fine.
The last MSI BIOS update for my board updated the Microcode 0x125.
The most current BIOS updates the Microcode 0x129.
I'm running the i5-13600K with no problems so far. <knock on wood>
19,203
Just be warned that the Dell i5-12500 that I updated to 0x129, is now going to a black Windows screen where only the mouse pointer is visible. I don't know if it's a borked Windows update or something to do with the microcode where it corrupted something important in Windows and preventing it from loading to desktop. If you have the same issue sooner or later, it could be the microcode (but for now, rest easy).
BoomerD
66,511
14,895
So far...no problems...so far.
DaaQ
2,028
1,439
Given the way Microsoft has been insistent on eliminating the workarounds, at some point they are gonna include code in a feature update that refuses to install if the requirements are not met. Only a matter of time.
I just reinstalled W11 Pro with Rufus late last month. Still typing on sig rig.
Will there be an X870e board with a 1xPCIE slot that will not reduce the X16 to 8?
Reactions: blckgrffn
Steltek
3,415
1,158
Yeah, I'm still scratching my head over that as well. Other than USB4, I see absolutely no reason to pay a premium for x870e over x670e at this point. Wasting too many PCIe lanes on all those extra m.2 slots, I guess.
blckgrffn
9,687
4,348
www.teamjuchems.com
Well -- all good advice. I'm not quite ready yet. Like I said, my best system uses this Kaby Lake K processor, 64GB of RAM, plenty of storage, and no problems running Windows 10. Everything of a serious nature that I do on a computer is integrated with printer/scanner and other hardware to support my life management routine.
I may have to buy some new software licenses.
Rufus + W11 iso image + remove compatibility checks = you’re going to be fine. 6th gen Intel is basically the same as 8th gen Intel (supported) and even MS bent the rules to support a 7th gen Intel in their own surface hardware.
Any DDR4 based Intel system is likely going to be “supported” even if unofficially for a long time.
I just did a i5-6500 Inspiron for kicks and it was very easy.
As for MS breaking it - I mean, maybe? They just started requiring popint as an instruction so all those Core 2 folks are out of luck 😂.
We do know W10 breaks next year.
DaaQ
2,028
1,439
Trying to figure out if I "could run NVME RAID" and a soundcard with out gimping the x16 top graphics slot.
Any help would be appreciated.
Or alternative, get M.2 drives first and see how boards shake out.
DaaQ
2,028
1,439
At the risk of being that guy - why?
Cause they made it available. Also its easier to get 2 4TB M.2 and make them a single logical, than to partition.
Look last drives a bought were 128GB SS drives however long ago that was, and they are RAID0 because one probably wouldn't hold the OS anymore.
Steltek
3,415
1,158
The reason the x16 slots are gimped in the first place is that those three onboard PCIe 4.0 NVMe slots are using up a lot of the available PCIe CPU lanes that in past years would have been used by PCIe expansion slots.
If you plan to RAID them, though, if you use the PCIe 5.0 m.2 slot as part of the RAID pair I suspect it will have to drop down to PCIe 4.0 speeds (which would defeat the purpose of having a PCIe 5.0 m.2 slot). You might be better off running a smaller PCIe 5.0 m.2 boot drive and then use two of the PCIe 4.0 m.2 slots for your RAIDed drives?
Just a thought.
DaaQ
2,028
1,439
Just a thought.
Yea giving the NVME raid second thoughts.
this is my other problem. Copied from somewhere else,
Will this run the 2nd PCIE2 slot at x4 as long as m2_3 is not used? But then NVME RAID would be disabled correct? I want to use a PCIEx1 soundcard, which the Nova "seems" to the board for it. BTW I have a 4x ssd RAID0 array because the drives were bought back when 128 for just under 100 was a good deal. Yea like 10 years ago. Was hoping to keep that for OS, or just get 2 M.2 4TB and raid0 them.
Easier on the wallet to get 2 than 1 8TB m.2
Thanks.
Steltek
3,415
1,158
Thanks.
Yeah, it would depend upon the motherboard. If you know what board you are going to use, you can download the manual for it from the manufacturer and see how the slot/m.2 assignments interact with each other.
You can still find boards with 2 PCIe x16 and one PCIe x1 slot, though they will probably be more expensive. I haven't looked closely at them, but I suspect they sacrifice a m.2 slot to allow this.
As a last resort, you can also get a m.2 to PCIe slot riser cable adapter, but how useful it will be depends upon how much power the PCIe 1x sound card you are installing uses.
Tech Junky
3,825
1,343
Actually it's easy to get a single U.3 dive beyond 8TB that runs at Gen4 or 5 speeds and avoid raid altogether. I went down the M2 road about a year or so ago and found the U drives soon after putting together the M2 version.
I had went with 4*4TB to get 16TB which is what my spinners added up to. So, those added up to ~$800 shipped but then I found a 16TB U.3 for ~$950 and wouldn't have to deal with the potential issues with raid and consumer M2 junk controllers. The single drive benches at 6.5GB/s where the spinners only hit ~450MB/s.
The U format though right now can reach as high as 60TB/drive if you have deep enough pockets and need that much capacity. The 30TB drives are running about $3500 at the moment while the 16TB are roughly $1200. And all you need is a dumb Oculink M2 adapter and a cable which comes to about $45 for the pair. If you want to get smaller drives you can get cards for 4 drives for $40 and a couple of cables for the drives for $70. It adds up a bit on the initial setup but, it's going to last longer than the consumer junk you're thinking about using.
Since the drives are more server oriented some of them run HOT and need active cooling while others are better at keeping the temps down.
Reactions: DaaQ
DaaQ
2,028
1,439
Good ideas. Love your way of thinking.
On that note. Are these really need water cooling. Corsair is selling some. I'd never but Corsair though.
I think a PCIE4 drive would be just fine. 4 TB seems like it may be small ATM. Since I found out my almost 500gb AND 1TB SSD were almost full due to my son's WoW crap.
I told him start looking for a case and power supply. I can probably put the GTX780 or the used Titan back together. But I do not like sharing my computer. Especially when things are downloaded without my knowledge.
bigboxes
42,478
12,433
Putting two NVMe drives in RAID is pointless. Zero need and another point of failure.
Tech Junky
3,825
1,343
Capacity vs cost
If you're cheap and use M2 instead of a U due to cost it's the only way to get beyond 8TB. The other factor may be speed by striping the disks you increase the speed per disk added.
In2Photos
2,621
2,792
I have to ask what the use case is that you need a drive larger than 8TB with the speed of PCIe4 or higher?
Reactions: bigboxes
Tech Junky
3,825
1,343
Higher capacity brings down the cost per TB and as for speed it's a modest price increase compared to prior Gen. It will age better over the long term as I tend to hold onto drives quite a bit longer than the other parts.
M2 drives top out at 8/G3 and cost $800+ where U 8TB drives are a fraction of that at the same speed. It's a balancing act of dollars and performance.
In2Photos
2,621
2,792
So there is no actual use case? Just like other enthusiasts I can't say you shouldn't spend your money the way you do. But this seems more like a want than a need.
Reactions: bigboxes
manly
13,440
4,158
Agreed.
If you just don't want another "drive letter," I believe you can just use an NTFS volume mount point.
Never before heard anyone say a 4TB drive for household Windows usage may be "small" already. I realize games are getting bloated; but we're not talking about media libraries which you could dump onto hard disk drives/NAS if your capacity needs are > 5TB.
Reactions: In2Photos
DaaQ
2,028
1,439
I'm not very concerned with the speed of PCIE4 but the motherboards are putting pcie5 above graphics slot. Was wanting to put 2 4TB in slots under graphics card. But then I also have pcie1 soundcard and don't want to cut the x16 into x8 for single graphics card.
I really don't want to have to watercool a storage drive either with the heat then pcie5 drives seem to put out.
Alot of these questions have came up because my adult son put WoW with mods on my PC. I thought I added a 2 TB SSD but it was 1TB. I have 4 128 in raid0 because that was the plan when I bought em. M.2 wasn't a thing yet.
I went to do an update and didn't have enough room. Because dummy didn't change the drive letter to D. So yea wanted to avoid drive letters.
Guess I'll see where the 8GB single prices are when the 9800x3d launches.
