I just shaved with a straight razor for the first time
jiggahertz
1,532
A good intermediate step would from a cartridge to straight is a DE. You can achieve the same closeness as a straight with a DE, but there is something special about honing/stroping your own blade. Also, depending on where your wife got the straight it may not be "shave ready". I'd recommend it getting honed professionally the first couple of times until you know how it should feel.
waggy
68,143
10
I love my DE razor. no way would i with a striaght razor.
but yes it takes a little more time. but i enjoy the process and the results.
Scarpozzi
26,392
1,780
Disposable safety razors are sharper than straight razors because the edge is much thinner. I watched a show on Discovery called "How it's Made" and they showcased the process. They explained that the blades are extremely thin and that they beat any other razor simply because a newly sharpened blade isn't dinged up like a resharpened blade. (for a blade of the same thickness) Quality control makes them superior to anything else, as long as the company manufacturing the blades has top-of-the-line equipment. Cheap blades on cheap razors are probably going to be less effective or last for a shorter period of time, but still work fairly good.
I'd say if you were shaving through a thick beard, the straight razor would be better because it wouldn't get clogged. For the touch ups, a safety razor is probably better. Having more blades just means less passes and less irritation for those with sensitive skin.
I can say from experience that going to the barber shop and having a straight razor shave was a good experience with the hot towels and lather, etc....but the shave wasn't nearly as close as my razors at home.
Feldenak
14,090
Originally posted by: WaTaGuMp
Originally posted by: silverpig
Sounds like a shitload of work for the same results. :confused:
I don't use a straight edge but I use a DE safety razor. At first it did take longer to shave with a DE but after a couple of uses I found it was just as fast as my Mach 3. I actually don't mind shaving now.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Check out these site if you're interested in "cutthroat shaving":
http://www.straightrazorplace.com/
There are pages of links from these sites to other places as well. You'll find sources and reviews for all kinds of shaving apparatus and alchemy ... soaps, aftershaves and aftershave balms, oils, creams ... also honing techniques, links to the youtube "how to" videos ... for straight razors, DE razors, even the 3|4|5| edge plastic razors, and how they all compare.
It's really hard to beat a straight razor shave, the DE's are pretty decent, and the blades are ~3.00-5.00 for ten versus $10-15.00 for six, so you can change the blades more often for a more comfortable shave more often.
Even if you're into more "modern" shaving equipment, the soaps, balms, and lathers can make the morning skin removal a little less ugly.
FWIW
silverpig
27,703
12
Originally posted by: Shawn
sounds like a waste of time. I usually shave in less than 10 min.
It was my first time... I'll be able to get it down to 10 minutes or less I'm sure.
silverpig
27,703
12
You'll come back. :D
As for pasta vs french food, come on. :laugh:
Oh I'm sure I'll use other razors at some point, but I had a lot of fun with this and would love to make it a regular thing.
Turducken >>>>>> French Food >>>> Pasta :)
Cheers,
Aquaman
No love for "Le Tofurkey"?
silverpig
27,703
12
Originally posted by: KingGheedora
Any fear that a twitch of your hand, or improper pressure and/or angle of movement at the wrong moment could cut your jugular?
I was worried at first about slicing my cheek off, but after I got the hang of it I moved with more confidence and realized it'd be pretty hard to do that. I wasn't scared of cutting myself at all by the end. If you use the proper sliding motion perpendicular to the blade, and keep it at about 30 degrees to the skin it's REALLY hard to cut yourself. If you turn the blade perpendicular to the skin and slice like a knife, then yeah, you'll have problems, but it's such a different motion that it'd be hard to make the mistake.
silverpig
27,703
12
Did you feel sophisticated?
What was that commercial again? It was for men's aftershave or deodorant or something.
Aww shit just what I needed, to try and remember that lol.
Right Guard?
That's what I was thinking... I couldn't find a reference to it though.
silverpig
27,703
12
FWIW
Any recommendations for a decent strop I can buy online? The store where my wife bought the razor is selling strops for $60...
Born2bwire
9,840
FWIW
I can't remember where I got mine but $50 is about what you'll be paying for a decent strop.
JDub02
6,209
When I was in college, the barber I went to used a straight razor for cleaning up the edges and shaving. The warm shaving cream was awesome.
Aquaman
25,054
13
Cheers,
Aquaman
turducken >>>>>>>>>>>>> tofurkey.
tofurkey is a mutated tofu thingy
turducken is a meat lovers paradise. takes some skill to make that sucker
Cheers,
Aquaman
ScottMac
Mar 19, 2001
5,471
Great strops, reasonable price (for the excellent quality): http://www.thewellshavedgentleman.com/
These are all hand made, cottage industry & all that.
ClassicShaving.com also has a good range of products, I bought a Russian leather strop ... it's good, but narrower than the one from WSG. The broader leather is easier to strop (especially when you're new to it) because you can keep the entire edge engaged for the full stroke.
http://www.classicshaving.com/page/page/522944.htm
FWIW, I have a couple straights, but I keep a couple DEs around too, for when I'm in a hurry.
Good Luck
Born2bwire
9,840
Good Luck
That's who I bought mine from, The Well Shaved Gentleman, I got the "Original" Latigo Hanging Strop. A very nice strop.
Ruptga
10,246
207
I "shave" with electric clippers, I have blonde hair so nobody notices the extra 1/8in. of stubble anyway. It's the quick and dirty way, but it works and it's almost impossible to cut yourself.
silverpig
27,703
12
Well I'll go and check out the one at the local store where my razor was bought. If it's a decent one I might pick it up for the $60.
Born2bwire
9,840
What is the store? It's rather rare for a store to sell badger brushes, straights, and strops.
silverpig
27,703
12
House of Knives. I even got some of that Col. Conk shaving soap there. I bought my Shun kitchen knife there, as well as all my knife sharpening stuff.
This is the razor
Kaido
Feb 14, 2004
51,941
7,408
My barber uses a straight razor to shave my sideburns and neck. I asked him if he used one at home personally. He said lol'd and said he uses a Mach 5 :Q
