i have to clean out my ear
Mutilator
3,513
10
Originally posted by: FoBoT
Originally posted by: Yossarian
if your hearing is that bad you should see a doctor.
i know, but i am one of those idiots that never goes to the doctor
You could always borrow Skiguy411's black widow and let her roam around in your ear to find out what's wrong. If she finds a problem she'll bite the location so it'll be easier for your doctor to find. ;)
FoBoT
63,084
15
fobot.com
Originally posted by: Spike
(I believe it is simply a modified stool softener)
are you telling me to stick a suppository in my ear?!?!? gack!
i dunno, the shop vac is sounding better with every post
Mutilator
3,513
10
It won't be sounding so good when it sucks your ear drum out. :p
Spike
6,770
The stuff you get at Osco, Rite-aid, walgreens, whatever that softens wax is basically a stool softener, but don't get all upset about it especially since it works. Whats better, pride or ability to hear? ;)
The stuff they put in your ear at the doctors office (at least the three places I have had do it) IS actually diluted stool softener, at least the stuff in the store is made for ear wax...
-spike
SaltBoy
8,975
11
Funny, I was having the same problem last week. I got the ear drop stuff that everybody mentioned, now my ear is doing great!
tami
11,588
Originally posted by: Juice Box
are you kidding? its SO easy...you can do it yourself!
Get some Q-Tips
Put some baby oil...or just water on the end.
Stick it in your ear...just be careful about it..you will feel if its gone too far
Go slow and spin the Qtip around..you may need 3-4 to get a lot of it out
And thats it...just dont go too far in...but ull know when its getting a little far
no, it's not that easy, especially if you wear in-ear headphones or earplugs. it pushes the stuff further in, and a q-tip can't get to it.
FoBoT
63,084
15
fobot.com
where did you buy it? what did you buy? are you just talking about the bulb ? i need relief, thanks
AMDZen
12,589
Spike,
So your saying that stool softener is actually hydrogen peroxide? I don't know what stool softener is, never had to use it, but I do know that all of these ear cleaning solutions are comprised of mostly hydrogen peroxide and water. I think their completely different things, and that your smoking the crack pipe again - but I could be wrong.
FoBoT
63,084
15
fobot.com
-spike
ok, if it will work, i'll jam it in my ear instead of my butt, i don't care anymore, it is starting to hurt and is beyond annoying
GasX
29,033
Debrox is an OTC product that dissolves was and cleans out your ears. If you are cheap, hydrogen peroxide and an eyedropper pretty much accomplish the same thing.
FoBoT
63,084
15
fobot.com
Originally posted by: AMDZen
Spike,
i don't care, i am going to buy some stool softening suppositorys and stick one in my ear, i am going for the NUCLEAR OPTION!!!!!!!!!!!!!!!!!
tfinch2
22,114
Lay on your side and pour peroxide in your ear. It will fizz like crazy for like a minute or two. Let it soak in and break everything up. If it's really bad get some qtips and wipe it down. After a few mins drain it and wash it out with water. Flip over and repeat with the other ear. When you work outdoors in construction or dusty areas no matter how much to clean your ears when you shower all that crap will build up and you need to do this.
BMdoobieW
3,166
I recently went to the ear doc and he used a vacuum type thing to suck it out. Many years ago I had a doctor pull it out with a metal hook and that hurt! My current doc said that you shouldn't use q-tips as that only packs some of the ear wax in much further.
TheNinja
12,207
squirt it out with warm water. sometimes the chunks are too large or hard so you could buy some of that ear wax softener stuff from the store to drop in your ear. leave in maybe 2-3 minutes and then flush it all out. it feels wierd at first but it's fine. in fact I want to do it right now as I'm feeling not so fresh.
Spike
6,770
Spike,
Well, I have NO idea what stool softener is made of, I am just repeating what the doctor told me. Plus the stuff they used did smell like hydrogen peroxide which is the same as the stuff I bought for my own ear at the store.
Either way the do it yourself stuff work VERY well and is not that hard to use. Plus it's really cheap. One thing to keep in mind, if you have unusually hard wax or alot built up (like it sounds like) you will have to do multiple applications. I occasionally had the issues where it would get worse after the first application as some of the fluid got stuck in my ear behind the wax. After a few applications it was all cleared out though.
-spike
Oh, and I don't own a crack pipe and never have but I do get accused of puffing it often... strange... ;)
Pacfanweb
13,158
59
Originally posted by: alien42
go to a bowling alley and stick your head in the ball cleaner. i bet that will clean everything including your brain.
Nah, that'll just polish him up real shiny
FoBoT
63,084
15
fobot.com
this isn't really working :(
i got the ear stuff from osco, i have done it 3 times since i got home from work
now my ear is totally blocked up
nothing is coming out when i flush it
it sorta bubbled when i put the stuff in and sorta bubbled when i rinsed it with H2O2 , but my ear is blocked up
i'll try one more day, then bite the bullet and go to a doctor
thanks for all the tips, i haven't tried the shop vac or suppository yet
