BoomerD
- Feb 26, 2006
- 66,357
- 14,769
- 146
Yeah, you can buy Win7 64 for around $100 with hardware. 6 year old computer? Dude, time to upgrade!
I used a flash drive, because for some reason the DVD worked fine in one of my drives but not in my brand new laptop (although other dvd's work fine). I searched around and found it was a pretty common issue. There is a tool that MS created that places an ISO onto a flash drive and makes it bootable, so if you have a flash drive, and another computer with a DVD drive, you could do that if you don't want to wait.
I haz no moneys for teh upgrade...:'(
I would never ever consider vista. ever.
Vista=Win7. It's pretty much the same damned O/S. Everybody hates on Vista because they were told to. A bunch of sheep following the flock....
I have this and can confirm that it is awesome! From power on to surfing the internet is about 20 seconds. Programs load almost instantly.
I only hate on vista cuz I had to repair my uncle's vista machine.
constantly.
what size did you go with?
I'm thinking I would need at least 128 gigs.
OCZ 120GB. Yes, I would recommend going as big as you can afford and only load your OS and most frequently used programs on it (Photoshop, Microsoft Office, Starcraft II, etc). I have about 40GB used on mine so far. If you get close to filling it up it will slow down the read write times drastically. I have an internal 1TB HDD for storage and downloads.
Damn it all
I was holding off on this because I didn't think it would matter that much. I'm a 2nd or 3rd gen adapter on stuff like this. Usually by then the prices are better and the bugs have been worked out. I've been wanting to upgrade to a quad core rig...maybe I'll save up a couple extra bucks and get an SSD to go with it.
I have a quad core i7 860 with 4GB of ram and Windows 7 and the difference in startup times and program loads times is literally like half. I click Excel 2007 and it pops up almost instantly, Photoshop takes about 2 seconds to open, Starcraft II takes about 6-8 seconds to load (less time staring at that ugly mug in the helmet the better). It is VERY noticeable. These things smoke Raptors or SCSI drives.
you asshole, I have NewEgg on the other tab and the deal of the day is a 90gb OCD2 SSD for $150
Lipstick on the Pig
So where does this leave us? For starters, we can now say with some certainty that the Windows 7 build I tested is just a repackaging of Windows Vista. Key processes look and work much like they do under Vista, and preliminary benchmark testing shows that Windows 7 performs right on a par with its predecessor. Frankly, Windows 7 is Vista, at least under the hood; if nothing else, this should translate into excellent backward compatibility with Vista-certified applications and drivers.
Except that it might not. The M3 build of Windows 7 breaks all sorts of things that, frankly, it shouldn't be breaking. Worse still, the suspected source of a major compatibility bump--the neutered UAC prompts--is in fact architectural in nature, one of the few truly new features of Windows 7's secure computing stack.
+1Vista=Win7. It's pretty much the same damned O/S. Everybody hates on Vista because they were told to. A bunch of sheep following the flock....
