Originally posted by: Scholzpdx
Originally posted by: Bu B3ar
Originally posted by: Barfo
AGP is a money pit, can't you upgrade your CPU and motherboard as well and get a PCI-E card that will be much better than any AGP?
If I'm doing that, I'm building a whole new system, and i dont have $1500 to drop right now. I'm just looking for a cheap extension on my rig until i have the loot to drop on a new build; i know my baby is at the end of her life![]()
Two example builds:
Intel Pentium E3200, Dual Core, 2.4GHz, 1MB L2 Cache - $53
ASRock G31M-S mATX - $44
2GB Corsair DDR2 667 - $30
Sapphire HD 4670, 512MB - $67
Total: $194
Intel Pentium E5200, Dual Core, 2.5Ghz, 2MB L2 Cache - $68
Gigabyte EP45-UD3R - $120
2x2GB Corsair DDR3 667 - $60
Powercolor HD 4850, 512MB - $97
Total: $345
The first build is significantly cheaper, but will also be significantly less powerful. The motherboard has a vanilla ICH7 southbridge, so if you want to get an SSD in the future, you won't be able to enable AHCI for increased performance. The HD 4670 is also significantly slower than the HD 4850. Either way, it will be more powerful than what you're using now.
With either build, you'd need to make sure your power supply is up to the task and has the right connectors (PCI-E, 4 or 8 pin EPS12V, 24 pin main connector, etc.). If not, figure in another $60 or so for a quality 350-500w unit with PCI-E connectors (Corsair, Antec, Seasonic, BFG, and PC Power & Cooling are all good choices; avoid cheap brands which will likely blow up and could damage other components).
Just something to keep in mind.
My laptop is faster than both of these builds.
:roll:
I appreciate the advice, dont get me wrong
