blackdogdeek
- Mar 14, 2003
- 14,453
- 10
- 81
I've been making corned beef in the crockpot for.. about 16 years and I do it a bit differently. I dump the corned beef into the crock pot (I do not use point cut, too much fat), and put in about 2 cups of water tops. It never goes over the corned beef. put the seasoning packet in and grind some fresh pepper. let it cook on high for about 8 hours, and then move it to low or warm. Cut chunks of cabbage up and put in, by this time, the corned beef is covered in its own juices and the cabbage will soak up some of this. Let it simmer for about an hour or so, just until the cabbage is cooked, but not slimy. You want the cabbage to have a little crunch still
Boom, done. No onion, no potato, just cabbage and corned beef. With Flat cut, you'll have a lot less fat to deal with also.
I made corned beef on Sunday and just finished up the last bit today with some scrambled eggs. It goes well with eggs.
on HIGH for 8 hours!? wow.
It's not too much water. You want to keep it completely covered with water on a low simmer during the entire cooking process. If you expose a portion to steam it will tend to bind the meat which makes it tough. A slow simmer in plain water will produce a tender corned beef.
btw, here's a spin on typical St. Patrick's day fare:
thinly sliced corned beef
mashed potatoes
boiled cabbage leaves
grated cheddar cheese
a bunch of scallions
Lay out a cabbage leaf flat. Fill it with some corned beef, a smear of mashed potato, and cheddar cheese. Fold over a part of each long end of the cabbage and then roll it up like a skinny burritto. Wrap 2 scallions around it @ 1/3 of the way from each end and tie tie each scallion in a knot. Sprinkly with a bit of salt and pepper.
I made these for a party last year on St. Paddy's day and they were a big hit.
Can you use broth instead of water?
No sense in me making another thread...
I have a pretty big brisket sitting in my freezer. What's the best way to cook it to make shredded beef sandwiches? I do not like bbq sauce, but I don't mind spices or other cooking liquids. Is it easy to make something similar to Chipotle's barbacoa, but better?
ime it's the heat that determines whether or not a corned beef comes out pull-apart tender. Any extended period of braising above a simmer can make for dry and tough.Now see, I cover mine about half way up with water. I found this helps make a brine that causes the beef to pull-apart tender. If you don't, it tends to get tough and dry. I also put carrots, potatoes, and quartered cabbage in with it about two hours into cooking, and even some smoked sausage (the kids don't like corned beef).
Been doing in this way for 20 years and it's a family favorite.
