Originally posted by: Insane3D
What is your total budget? Also, do you need everything, or just the head unit and an amp? For what you want to do, the 750MP seems to be a perfect fit for what you want to do. 🙂
Alright, the ones you linked me to are perfect since they are pre amped and would be pass through an amp before going to the speakers? What's the significance of having a hgih volt output?? More power??
Also, you said 3 external amps, does that mean that each pair of speakers would need to go through an amp?!?!
I would need the Head unit, Amp( If it will give me better sound ) and speakers ( A pair of tweeters, front speakers and rear. Budget can be worked around pending on the performance that I will be getting. I won't be using a sub.
Ok, you will have two types of outputs from the head unit. You will have "high level" outputs from the head unit that are powered by the cunits internal amp. You can hook up four speakers off the head unit's amp.
The second type is a "low level", or pre-amp which is a non amplified output meant for an external amp. The standard voltage for these outputs is 2v, higher output models have 4v outputs, and the newest high end models, like the 750MP have even higher 6v outputs. The advantage to having a higher voltage output to the amp is a cleaner, stronger signal to the amp.
No, you would have two sets of "high" outputs for running speakers of the internal amp...front and rear, right and left.
You would also have three set's of "preamps", non amplified outputs for connecting to an external amp...front, rear, and non-fading sub.
What kind of car? What size speakers are in it now? I would suggest normal 2 or 3 way speakers for the rear, a component setup for the front, and maybe one amp and a small sub...or, budget permitting, another amp for the components in front.
What type of music do you generally listen too?
You have a couple choices. You could run the front and rears off the head unit's amp, and have a small 2 channel or mono amp powering a 8" or 10" sub. You could also bypass the head units' amp and get a four channel amp for the front and rears...or, you could get a small 2 channel amp for the fronts, and run the rears right off the head unit.
It sounds like you aren't a big audiophile or anything, so you will prolly be fine running the fronts and rears off the internal amp, and just getting a small amp and sub for bass. Running your speakers off an external amp won't really make them sound "better", just louder.
The car they are going to be in is really important. Different cars all use different size speaker configurations, and without knowing where they are going it's really hard to buy. For instance, you might buy a set of 6 x 9's, and then find out the car you have has 5 x 7's or 6.5" models, and you would be out of luck unless you built custom speaker boxes.
Component speakers are usually in two parts...a set of tweeters and a set of drivers.
Alright, let's say I do this. Get the Pioneer head unit that you suggested, front component speakers, rear 2 way or 3 way speakers and a 10" sub. Can I just get a multichannel sub to power the front and sub? Or do I need a separate amp for the sub and fronts?
I'm afraid of killing the speakers like I did to my current ones. I think I abused the volume too much.
Originally posted by: rbloedow
Whoa Nelly.
Okay now, what's going on?!?!?
Will someone tell me?
There was another car stereo thread awhile ago, I think it went crazy, can't remember
