Nitemare
- Feb 8, 2001
- 35,461
- 4
- 81
Get them surgically fixed. I had a bad set that hurt all the time and recently had a podiatrist fix them.
They spray on a local anesthetic. Then they inject a 50/50 mix of lanacain and marcaine to further dullen it. Then they take what looks like a wire cutter and snip off the bad section of toe. They twist it and pull it out by the root. then they apply some acid in the corner to kill the toenail root of the side that gets infected. if you suffered half as much as I did I would advise you to get this done.
