Umm...So the trick is to install x64 Vista but run x86 apps - or run x64 apps with reduced functionality...
Originally posted by: AMDZen
So I am brand new to Vista as a whole, and made the jump strait to x64 so I have a quick question (this seems to be a pretty good place since people are discussing flash)
I installed Minefield last night and went to a site that needed flash, I installed the flash plugin and instant bluescreen. OK. So I understand I can install Firefox 32-bit (I didn't really understand this before) but in regard to IE7, how do you differentiate between the 64bit and 32bit IE7's? I see IE7 and thats it, so I'm assuming it the 64bit version, do I need to go to the Program Files (x86) and find the IE7 and create a shortcut to it which would (presumably) be 32bit?
Originally posted by: mechBgon
I use 64-bit IE primarily when I'm out actively looking for malicious websites. Mandatory DEP enforcement is one reason.
Originally posted by: QuixoticOne
Are you saying that the 32 bit IE doesn't have the same level of DEP protection as applies to the 64 bit version or all other programs in the system?
On a Vista system, go to 32-bit IE7's Tools > Internet Options > Advanced menu and scroll down to here :camera:. This is 32-bit IE7's dedicated DEP control. It's not enabled by default, probably because too many browser add-ons would crash.
To enable it, right-click 32-bit IE7 and Run As Administrator, and you should be able to enable it. AFAIK, DEP is mandatorily enforced on all 64-bit apps, period, thus the use of 64-bit IE7 (in Protected Mode, of course, plus a dedicated non-Admin account and SRP) when lookin' for trouble.
Originally posted by: ChronoReverse
You also need UAC to be turned on for Internet Explorer's Protected Mode to work (basically a sandbox mode).
Originally posted by: Canterwood
No upgrade path from XP x64 to Vista x64.
Bit of a deal breaker for me tbh. :thumbsdown:
Originally posted by: stash
No, Core Duo does not have 64-bit support.
It's pretty amusing watching people work themselves into a froth trying to get it though.
It seems pointless (and stupid) to me to have an 'upgrade' path that requires a clean install tbh.Originally posted by: mechBgon
Microsoft's upgrade-path chart seems to indicate that XP Pro x64 qualifies for the upgrade to Vista, you just have to do a clean install. Any good?
