I finally had to give in to old age.
dmcowen674
54,889
47
www.alienbabeltech.com
Originally posted by: shilala
My monitor is a Samsung 712n LCD.
I'm 38 years old, Skoorb.
I set my refresh rate to 75. Windows says my monitor won't support higher than that. I'll check the specs on my monitor...
Resolutions supported 1024 x 768 ? 1152 x 870 ? 1280 x 1024 ? 640 x 480 ? 720 x 400 ? 800 x 600 ? 832 x 624 ? 1152 x 864 ? 640 x 350
Synchronization Range - Vertical 56 - 75 Hz
Synchronization Range - Horizontal 30 - 81 kHz
Max. Viewing Angle - Horizontal 160
Max. Viewing Angle - Vertical 140
Native (Recommended) Resolution 1280 x 1024
You should be able to set it to at least 72 HZ.
Go to Apadter, then advanced and click on List All Modes.
Pick the highest resolution at 72 HZ and your eyes and brain will thank you.
I set up at 1280x1024 truecolor at 75 hz. (72 hz wasn't an option in list all modes)
I'm not fond of it, but I'm going to get used to it.
Thanks!!!
Beautiful, even better. Your eyes & brain will enjoy it.
You're welcome.
Insane3D
19,446
Thanks!!!
You're welcome.
Dave, did you notice he has an LCD? Refresh is irrelevant on an LCD....
dmcowen674
54,889
47
Thanks!!!
You're welcome.
I have one too, you'd be surprised. It's not neccessarily how the LCD reacts, it the way the Video card presents the image.
myusername
5,046
my monitor is so old that it flickers worse at 85 than 75. Waiting for the 2405 to hit the 500 dollar mark :D
cavemanmoron
13,685
59
MonitorsDescription
Monitor PTS 2606
Max. Resolution (HxV) 1600 x 1200 pixels
Screen Size (HxV) 37 x 27 cm
Viewable Diagonal Size 18.03 inch
Manufacture Date August 2000
Serial Number 198757
Video BoardDescription Your Results
Brand/Model SiS 530/620
Resolution 800x600 pixels
Colors 65,636
DirectX version 5.03.2600.2180 (xpsp_sp2_rtm.040803-2158)
OpenGL version 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
Acceleration options Enabled
Performance 25.22 MP/s (No similar CPU/MHz/video)
800x600 85hz
I normally sit back where my foot can Almost touch the monitor.
boomerang
18,883
641
Kick the refresh back down to 60hz. It's doing you no good higher and sounds like it's making it worse.
ClearType will be in Control Panel if you downloaded it as a Power Toy. Otherwise, in Display Properties, Settings tab click Effects.
I'm running 1280 by 1024 on a 19" LCD with 120 DPI on fonts. What burns me about increasing the font size, is apps that can't cope with it and display kinda screwy. Microsoft AntiSpyware is one of them.
Again in Display Properties you can click Appearance tab and Advanced and start changing Font sizes for diffferent items. It's a hassle though.
38 is a fond memory for me. :brokenheart:
ElFenix
102,407
8,595
I run 1600 x 1200 on this.
I agree 16 x 12 is a bit over the top on a 19" unless you adjust the font size..
i never adjusted the font sizes and ran 16x12 on a 19" crt for about 5 years. now i've got a 2005FPW and its taking me a while to get used to the larger text size. sat out of arm's reach of it too.
