I failed in unlocking my AthlonXP!
WinkOsmosis
Banned
Sep 18, 2002
13,990
Originally posted by: IdahoB
Do you have a circuit tester? I know it's tricky because of the size, but you can use tape to stick a pin to each point of the circuit tester, which gives you a small enough point to test each bridge with, as well as test each bridge with all the others to make sure you haven't made a short circuit. Essential for this kind of work so you don't have to keep re-assembling the CPU/Heatsink in order to test it. Keep at it, it's not that hard really. And you really ought to use superglue and proper conductive ink.
It is proper conductive ink. Circuit Writer from Fry's. I gave up anyway. I wasn't using a pin though. I was using an Xacto knife, and then a piece of modelling wire cut to form a tip. Maybe a pin would be easier.
HoMeZ
394
Originally posted by: human2k
screw unlocking your cpu! go screw your gf!;)
I AGREE!!!! DAMN If that is really your g/f why are you trying to unlock your processor? =Þ
What does unlocking it actually do? Just let you change the multipliers?
IdahoB
458
Originally posted by: HoMeZ
Originally posted by: human2k screw unlocking your cpu! go screw your gf!;)
I AGREE!!!! DAMN If that is really your g/f why are you trying to unlock your processor? =Þ What does unlocking it actually do? Just let you change the multipliers?
Exactly, although it's not always necessary if you have an Nforce2 board.
