SirChadwick
- Jul 27, 2001
- 4,595
- 1
- 81
Originally posted by: Cattlegod
first off - what kind of car?
second off - it is probably lost. the door inner and door outer are put together solid. the only holes in the door inner are the holes for speaker openings and grab handle openings. other than that, nothing is big enough to get your hand in. you might be able to reach in through your front door speaker (if you have one).
else you are SOL unless you want to remove all of the door handle assembly.
edit - just pay the 7 bucks and get a new DL.
LOL, you've clearly never taken one of those panels off. Those clips are AWFUL, though...worst. idea. ever.
Are the hours that you will spend trying to get the panel off worth the $4 it would cost to get a new license?
If that were true how would you service the locks, power window motor and assembly? Cut off the outer door skin?
there is one hole that a "door module" is placed in. the whole thing goes in/comes out as one large unit.
