Josh123
I'm likely much closer to my server than you are to yours. When I was on Black Dragonflight I averaged around 120ms.
I chose my current server specifically for it's low latency. If you're ever considering transferring, roll a level 1 on your target and run to your capital city during peak hours. Dance on the mailboxes, run around /flirting with high level players, and generally goof around while keeping an eye on your latency. That'll give you a decent~ish idea of what you're in for if you choose to make that your new home.
Having said that - There's a couple things you can do: The first is you can also set your network to not group packets, and instead send them immediately as they're generated. If you don't know how, hit up Curse and DL/Run the "Leatrix Latency Fix" - It's a script which will set that for you. That can reduce latency.
The second: Some firewalls will allow you to prioritize traffic by application. There's also an app called "Net Balancer" which will do that - The free version only does a couple programs, but more than enough to do things like set WoW for Priority and your bittorrent to low.
I really wish we could xfer heirlooms because I would move because Kalecgos blows. The only thing I've done to try to improve my latency is the TCPackfrequency edit in the registry.
