I dont know what to do... EDIT: PROBLEM SOLVED!
Just finished building my computer with the following specs:
Case Thermaltake Tsunami
Power Supply OCZ Modstream 450w PSU
Motherboard MSI K8N NEO4 Platinum
Processor AMD Athlon 64 3000+
RAM Corsair Value Select 1GB(512MBX2) PC3200 400MHz
Hard Drive Seagate 80GB S-ATA, 8MB cache
DVD-ROM NEC 3520A Dual Layer DVD Burner
Floppy Panasonic Internal Floppy Drive (Black)
Vid Card ATI Radeon X800XL
I can get into the bios and change stuff around but when I get past that and try to run the WINXP cd i have, nothing happens. Well something happens: Disk boost failure. "Insert system disk and press enter."
I don't know what to do. What does the error mean? Is their something wrong with the HDD? The CD? The optical drive? The MSI board says it's starting the OS (According to the D-Bracket that was included, all four leds were green) but nothing happend other than the error.
This is my first build, so try and be patient with me and explain things in detail if you can. All help is appreciated guys!
usually what that errors means is it cannot find an active os to load from, what you will have to do is go into the bios settings and change the boot order of the system to boot from the cd/dvd rom drive first before the hard drive (cant grab the manual... its not letting me download it) but your manual should tell you.. once that is done it should boot from the cdrom and say press any key to load
lol, dont feel too bad, i rebuild a whole machine, using the same cables, and it turns out i had a bum ide cable as well. It can happens to us all
(luckly it was a new machine)
