- Apr 8, 2001
- 32,539
- 260
- 126
Actually maybe not, but that's how the song goes.
On the plus side I got to troubleshoot their AMEX checkout and found that for some reason if your newegg account email account isn't the same as the one you have for your Amex account, then even if you order an item while logged into your newegg account it will automatically process the order under a guest account so you won't have any indication of the order in your order history.
The bad would be the agent seeming to be happy that I "fixed" the issue and I doubt any further work will be done to actually fix the problem.
I don't recall this happening when using visa or mastercard checkouts before, has anyone else seen this?
