I can't connect to networks using my WiFi antenna
chrstrbrts
522
Hi,
I just purchased a Signal King SK-11TN USB WiFi antenna.
It seems to do a good job of finding networks that otherwise wouldn't have popped up on my wifi adapter's radar screen.
Many of these networks appear to have a strong signal, many with 3 and 4 bars.
But, whenever I attempt to connect to them, I usually get an error message stating that a connection couldn't be established.
I don't mean that there was some kind of security I couldn't circumvent; I'm never asked for a password.
It doesn't even get that far; it seems that I can't communicate with these networks at all.
Why is this happening, and how can I fix it?
Ichinisan
28,298
1,235
Hi,
You would need to boost or focus your
transmission or they would need to have a high gain receiving antenna.
Try a directional antenna...?
razel
2,337
93
101
Verify that it works at all in the 1st place with a known good WiFi connection.
sonitravel09
217
4
46
Did you use the TPlink drivers or did Windows install them?
What modem do you have?
I've got a TPlink (but not the same as yours), too their drivers arent that good.
