BrokenArrow64FX
I would go with the 64 bit proc. You should also wait untill socket 939 becomes affordable.
Originally posted by: Bad_Dude
I thought about keeping the Athlon64 and get the ChainTech board. But after seeing that no one could get 3X512MB Sticks to work in all 3 slot b/c of the double sided RAM. That would means I can only have 1Gig of RAM. While the Intel P4 setup requires dual channel, I can get 2Gig on it. I would think that the RAM will help speed things up also. What do you guys think?
Thanks.
Originally posted by: ALIEN3001
2 CPU intensive things at once, not just "2 things at once".
Thanks.
I havent seen any games that can benefit from more than 1GB of memory.
I will NOT be going AMD64 until the OS AND SOFTWARE has matured at least 1 year. If MS can mess up 32 bit this bad, 64 is gonna be sorry for a while...
There is always the issue of multitasking, if you do more than 2 things at once on your pc, you are going to see tangible performance advantages for the P4 with HT.
Thanks.
Originally posted by: justly
Sell the Athlon 64... BTW how much do you want for it 😉 😀
Originally posted by: nick1985
only the diehard intel zealots are voting for the 3.0.
I had a 2.4b@3ghz and my Barton@2.43ghz was faster across the board. The higher fsb and HT make the P4 what it is now, I'd take a mobile Barton over a P4b any day. Also, stability with either platform isn't a factor for the experienced builder who does their research 😉Originally posted by: zanejohnson
I'd go with the P4c 🙂
i had never owned an intel machine until i built this one a year ago, and now it would take some major advantages for me to to back to AMD. Mostly because damn, this system has been SO RELIABLE. Im pretty sure the only time i can ever remember it throwing a BSOD was during the overclocking process.
Its over a year old, and it still doesnt feel "slow" to me, like every other computer i've ever built.
my rigs a P4b 2.4 @ 3.15/700, 2 20gb 7200/2mb's in RAID:0, and my CPU overclock is limited by an old stick of PC2700 memory... which i'll be able to replace and hopefully yield ~3.4GHz later...
