SonnyDaze
- Jul 31, 2004
- 6,867
- 3
- 76
Originally posted by: Evadman
You need to invest in some sandpaper and filler first. Then I would paint it to match your decor. Use 2 or 3 coats of primer, 4 or more in the edges. MDF soaks up paint like a sponge.
:thumbsup: Agreed. I built some utility cabinets in the garage with MDF and they definitely require primer if you want a decent finish. Also on the ends that have been cut, make sure you use a sealer OR you can use a 50/50 mixture of wood glue and water to seal with. Just mix it up and brush it on. Once it dries sand it lightly.
