I bought a 1/2 inch drill bit tonight.....but it won't fit in my power drill! Little help? **Resolved**
sohcrates
7,949
Is there an adapter or something i can get? Or do i just need a bigger drill?
Edit: See my post below
Sluggo
15,488
You need a bigger drill, or a 1/2" drill bit that has a smaller shank to fit in your 3/8" drill.
I never thought that I would use the word "shank" in these forums.
JC
5,836
64
Chuck that 1/2" drill bit up in your lathe, and turn down the shank to 3/8" or so...
Oh yeah, since you don't have a 1/2" drill, you prolly don't have a lathe either! Just go get a reduced-shank drill bit :)
JC
Moonbeam
74,051
6,601
You can get a block of wood, a bow and string and drill like you were gonna make fire.
sohcrates
7,949
So instead of dropping 10 bucks on a 1/2 inch bit with a 3/8 inch neck or what not i picked up a PHAT 1/2 inch high torque drill at home depot last night for only like 50 bucks.
Woo hoo!
Thanks for the help :)
